Voltage regular???
Old Jan 15, 2003 | 10:48 AM
Traveller_NC's Avatar
Traveller_NC
Voltage regular???
I have 1986 Bronco 302 efi aod....
I am not a mechanic but where is the voltage regular located???
My truck would not start, had to jump twice to drive 20 miles to home.
Check Battery = ok
Check Alternator = ok (14 volts)
Could it be bad voltage regular?
Old Jan 15, 2003 | 11:42 AM
Mil1ion's Avatar
Mil1ion
Voltage regular???
That one could be integral to the alternator.
Otherwise, look for a silver box near the starter solenoid on the right inner fender.
Dennis
[i]F.T.E. Assistant Administrator
http://www.clubfte.com/users/mil1ion/starfleet_command_e0.gif
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Jan 15, 2003 | 02:11 PM
truckfreak69's Avatar
truckfreak69
Voltage regular???
Old Jan 21, 2003 | 01:42 PM
Traveller_NC
Voltage regular???
[QUOTE]Originally posted by mil1ion
[B]That one could be integral to the alternator.
Silver box...i am not sure if i can ever see the color silver...it may be covered in dirt...do you mean map sensor? or something?
Old Jan 21, 2003 | 07:06 PM
Mike W's Avatar
Mike W
Voltage regular???
Voltage regulator is approx 3x3x1" with a four pin plug in the side.
Old Jan 21, 2003 | 11:55 PM
83Steve's Avatar
83Steve
Voltage regular???
The regulator is usually attached to the R inner fender near the starter relay, but your problem sounds more like a bad starter relay. When you change it, get the newer style where all the posts point the same direction.
daveengelson
Feb 22, 2017 02:10 PM
Trevorafish
Feb 5, 2017 12:10 PM
hunter29078
1983 - 2012 Ranger & B-Series
53
Oct 10, 2015 12:37 PM
talkas
Apr 14, 2014 09:55 PM
aa767man
Oct 4, 2011 09:34 AM
