Positive deck clearence
Old Jul 16, 2008 | 08:25 PM
Goose_52's Avatar
Goose_52
I have a set of TMI 9.5:1 CR pistons in my block, and while degreeing my cam today, I noticed the high side of the piston(near the valve relief) is about .008 above the deck. Is this supposed to be like this? I cannot imagine it would be. I know this block has been rebuilt previously, now I am wondering if the machine shop decked the block too much. I will call Tim tomorow and get his input, but maybe one of you guys would happen to know also.
Old Jul 17, 2008 | 01:33 AM
hollenjoe's Avatar
hollenjoe
hmmm i gave thought to this and i asumed tims pistons are not exactly 10.297" due to the fact that most rebuilds take a bit from the deck and heads, its not that bad to have your pistons that up, but you have too watch yourself for compression and cam choice....when doing such choice make a post....
Old Jul 17, 2008 | 11:28 AM
beartracks's Avatar
beartracks
I'm not sure if the combustion chamber can take that or not but at 9.5 to 1 you should still be noticably donw in the cylinder.
Old Jul 17, 2008 | 03:47 PM
80broncoman's Avatar
80broncoman
.008 is no problem at all as to having enough room.
I just got my TMI pistons in my block (in a engine that also has been a remaned unit) and one of mine is about .012 above the block. I going to run this way. The rest of mine range from Zero to +.010
I have seen plenty of engines built using flatops up .015 out of the block with a .045 headgasket. It will raise compression slightly.
Old Jul 17, 2008 | 10:29 PM
TMI's Avatar
TMI
Those pistons have a comp height of 1.710" this theoretically will give an extra
.010" for resurfacing. We have seen the 400 engine deck height being way off.
By time you get you block flat and even bank to bank, we have seen it down .010"-.015" below the "Zero"
Also crankshaft grinding can change either way if not watched.
Old Jul 18, 2008 | 09:48 AM
beartracks's Avatar
beartracks
I'm not familiar with the pistons but wont they hit the head if they protrude out of the cylinder?
Old Jul 18, 2008 | 02:47 PM
80broncoman
If you are refering to a stock 400 head it has a large open chamber so no chace of it on that one.
If you are refering to my statement about other engines being built with flattops out of the block, a normally thick gasket (not a thin race gasket) will will be thick enough to keep head from making contact.
Old Jul 18, 2008 | 06:47 PM
tvanleeuwen's Avatar
tvanleeuwen
When we got my 400 together, my pistons were .010 above the deck. I'm running aussie heads, with Tim's pistons made for the aussie heads. I called him and he said that as long as it has .030 piston to head clearance, which can be achieved with a .040 gasket, it is okay. He said that this is normally where their pistons end up.
mustang81
13
Feb 16, 2010 04:14 AM
Argess
41
Feb 8, 2009 07:11 PM
nate5812
Oct 17, 2004 10:40 AM
cody66
Aug 18, 2002 04:25 PM
timhoe
Jan 29, 2001 10:12 PM
