VIN Help!!
Old Jul 15, 2008 | 03:34 PM
igortoys's Avatar
igortoys
VIN Help!!
Hello, I could use some help decoding my vin. I just purchased this truck and I'm not sure what year it is (was told it was a 67). I do not have a title (not required in GA for vehicles over 20 years old). VIN F10ANC00772. Im also trying to find out what gear ratio was in the rear. Funny thing is they put a 289 from a mustang in it. Does anyone know if parts from a 302 will fit on a 289? Thanks in advance for all your help.
Old Jul 15, 2008 | 10:43 PM
Shoestring's Avatar
Shoestring
Guidelines violation removed
Old Jul 18, 2008 | 07:36 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
F10 = F100 2WD
A = 240 I-6
N = Norfolk VA Assembly Plant
C00772 = 1968 (1968 serial number range: C00,001 thru D82,000)
The AXLE code is not in the VIN.
Look on the Warranty Plate, located on the left door face below the latch for the AXLE code...second line at the right...post it here.
289/302 compatibility...most parts interchange.
Old Jul 18, 2008 | 07:49 AM
NumberDummy
Originally Posted by Shoestring
Ok first off you have a 67 built in August.
fficeffice" /><O></O>
F10 means F100 2WD
5<SUP>th</SUP> digit N means built in ffice:smarttags" /><ST1lace w:st="on"><?xml:namespace prefix = st1 ns = "urn:schemas-microsoft-comNorfolk</st1:City>, <st1:State w:st="on">Va</st1:State></ST1lace>
Hope this helps.
It didn't help, because the info you posted is in-correct.
New vehicle introduction is in September, so a truck assembled in August of 1967 will be a 1968 model, and the VIN's serial number proves it.
Old Jul 18, 2008 | 11:09 AM
Shoestring's Avatar
Shoestring
I just followed the web page that I posted. Yes built in August but listed as 67. So yeah that was off but the page posted was spot on.
Dave King
Aug 20, 2012 12:24 PM
airborn406
16
Jun 17, 2010 06:12 PM
zeos
Oct 10, 2006 07:05 PM
blueoval65
Nov 28, 2005 12:17 AM
nzabka
Sep 29, 2005 05:13 PM
