223 harmonic balancer
Old Jul 15, 2008 | 11:40 AM
DakNSak's Avatar
DakNSak
Hello all,
I am looking for a harmonic balancer for my '58 F100 223. I havn't had much luck with the usual parts sources. I would take new or used in good shape. Does anyone have one or a good source. The one I have is a single pulley with the following numbers stamped on it: 6316A EBP the other side is 125734 SCCO. Also the timing chain and gear.
Thanks
Old Jul 15, 2008 | 08:41 PM
manglass's Avatar
manglass
Sorry, I don't have either but here are a couple of ideas for sources.
Harmonic balancers are available rebuilt, look around the internet. Here's one source:
Damper Doctor Online: Ford
The timing chain and gears are the same as the Y-block V-8, I've even seen the double roller type from Summit Racing.
If you're looking for stock, always try NAPA. A local store might not have them in stock but probably can order from the warehouse.
Hope that helps,
Lou Manglass
Old Jul 15, 2008 | 08:54 PM
DakNSak's Avatar
DakNSak
they do have one but they sure don't give them away!! $160+ shipping. Thanks for the source though, I guess I'll half to bite the bullet.
Old Jul 16, 2008 | 09:43 AM
manglass's Avatar
manglass
Don't be afraid to look around, there are lots of other damper rebuilders. I only sent you the first one I found in my bookmarks. There are others on the internet and look in Hemmings too. You might also try the local junkyards and pull-a-parts. With the price of scrap so high a lot of vehicles are coming through that you don't normally see. If I had a good used one, I'd be glad to share.
Lou Manglass
Old Jul 16, 2008 | 06:19 PM
bigwin56f100's Avatar
bigwin56f100
I got a good used one $75 shipped any where in the 48. Please only PM or e-mail if interested.
Old Jul 16, 2008 | 07:29 PM
DakNSak's Avatar
DakNSak
I ended up getting a newly rebuilt one today. Thanks for the reply though. Hopefully the Hoemobile will be up and running soon!
jvmcc
Nov 8, 2015 09:04 AM
jvmcc
Nov 7, 2015 02:44 PM
woodhd
Nov 25, 2014 11:29 AM
taylor90
Feb 22, 2012 04:30 PM
MIKEDEL
Dec 15, 2011 06:43 PM
