Ford 223 Harmonic Balancer / Crank Pulley
Old Nov 4, 2014 | 09:33 AM
woodhd's Avatar
woodhd
I have a 1964 ford f100 with a 223 inline six. Im looking for a harmonic balance to get my truck back on the road. The one I have has split and the pulley has a chunk missing out of it. I have called numerous salvage yards and parts distributors with no luck. I'm hoping someone might have one available. I appreciate any help you can give. Thanks
Old Nov 5, 2014 | 02:11 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1964 balancer (C4TZ-6312-E) is 1964 truck only, why I don't know. 1957/63 balancer is different (C3AZ-6312-C *) and it's also the same as 223 Passenger Cars.
The crank is the same 1961/64 car/truck, the M/T flywheel is the same 1954/64 car truck.
There are two types of 223 A/T flexplates, one type was only used in 1964.
C4TZ-6312-E .. 223 I-6 Harmonic Balancer-contains a single sheave pulley / Obsolete
Applications: All 1964 223 I-6 trucks / No Ford dealer or obsolete parts vendor has any.
*There are 5 C3AZ-6312-C harmonic balancers available NOS (see below) .. but I do not know if this balancer will work on 1964's.
OBSOLETE RELIABLE PARTS in Nashville GA = 229-686-5101.
> > Damper Doctor (damperdoctor.com) is located in Redding CA < <
Old Nov 25, 2014 | 11:29 AM
woodhd's Avatar
woodhd
Thanks for the information. I found one off a 1960 223 and installed it. The pulley was slightly smaller diameter but the truck is up and running. Will the difference in the pulley size or the harmonic balance cause me problems down the road. Thanks
jvmcc
WTB - Parts & other
Nov 8, 2015 09:54 AM
gangstakr
Dec 26, 2014 10:26 PM
1999stroke
Jan 13, 2014 03:35 AM
Log Hog Kust'em
Jul 12, 2012 03:29 PM
morse
Mar 1, 2009 05:31 AM
