203-205 Doubler Problem
Old Jul 14, 2008 | 09:23 PM
suzuki1750's Avatar
suzuki1750
Ok, i finally got my doubler kit from Off Road Design. After removing the range box from the 203, I decieded to disassemble it to clean the case. Everything went good until i removed the hi/low gear shaft and 72 needle bearings fell on the floor. What is the easiest way to reinstall these? I am thinking grease to help hold them in place, but i think it is going to be a pita, because i have to press the shaft into the case without the needles falling out. Any suggestions?
Old Jul 14, 2008 | 11:25 PM
75F350's Avatar
75F350
Simply grease the inside of the idler gear and then neatly lay all 72 needle bearings, place shims and spacer back in place and then reinstall everything in the reverse order in which you pulled it apart.
Not all that difficult.
This might help. There are 15 more of these little guys that are going to also be very important. Dont forget those.
NorthWest FabWorks - Tech Index - NP203/205 Installation Manual: Page 1 Of 3
Pipelinewelder20
15
Oct 2, 2014 03:56 PM
79Ford4x4
Offroad & 4x4
Jul 17, 2010 09:06 AM
Hazmat 67
Jun 2, 2010 08:18 PM
Opossum
Offroad & 4x4
20
Nov 25, 2008 02:03 PM
apachetech
Offroad & 4x4
Jan 10, 2006 11:17 AM
