Offroad & 4x4
NP203 disassembly question
Old Jan 10, 2006 | 09:07 AM
apachetech's Avatar
apachetech
Question NP203 disassembly question
I am tearing down my 203 to build a doubler and I am down to the lower gears on the front gear section. Are the lower gears press fitted into the case? How do I remove the lower two gears?
Thanks
Old Jan 10, 2006 | 09:13 AM
teds74ford's Avatar
teds74ford
Hey, I was looking around. Maybe this will help?
http://www.wideopenwest.com/~rballar...isassembly.jpg
BTW, can you look up U-bolt and leaf spring bolt torque specs for me? I forgot to write it down before I gave you the book.
Old Jan 10, 2006 | 10:46 AM
ivanribic's Avatar
ivanribic
I wish I had my case here because I can't remember the details now but you shouldn't need to pull any gears to seperate the range box from the rest of the case. The output shaft from the range box to the chain box will slide right out and let you seperate the two halves.
Old Jan 10, 2006 | 11:17 AM
apachetech's Avatar
apachetech
I figured it out. I tapped the shaft out and the gears were able to come out. There is two shims in front and two in back with needle bearings around the shaft. I'll go and get those torque specs Ted and send you a PM.
Thanks for the replies.
Tinstar36
156
Feb 4, 2021 09:59 PM
nsboyd1210
WTB - Parts & other
Sep 18, 2015 09:14 PM
ksmith203
WTB - Parts & other
Sep 30, 2012 07:25 PM
401477534
Apr 14, 2011 06:34 PM
jermyjudge
WTB - Parts & other
Sep 15, 2010 09:20 PM
