Transmission options for a 302
Old Jul 14, 2008 | 10:59 AM
BFOOTER03's Avatar
BFOOTER03
Looking to replace my tired 272 with a 302 and need some transmisison help. I was looking at T5 but was concered with the shifter being so far back. Can anybody odder some help or experience for me? Thanks
Old Jul 14, 2008 | 11:47 AM
mcdonaldm's Avatar
mcdonaldm
you probably have 3 pratical choices if you want to go the stock/boneyard route.
you can use the T5 from a 302 mustang, an AOD or even the c4 if overdrive is not an issue.
the T5 can be converted to bring the shifter farther forward. i think they use the tailhousing from a S10 truck as this places the shifter farther forward. there are also kits out there to modify/convert the T5 shifter location to where you want it.
the AOD is another popular choice. the biggest issue is making sure you get the tv cable installed and operating properly. Lokar makes a cable kit just for this application (aassuming you are using a carb, if efi, then the AODE transmission is the one to use along with correct computer)
the C4 is a tried and true transmission. very straight forward and easy to install. no overdrive is only negative, but virtually bullet proof with a good rebuild.
of course there is also the vast aftermarket for just about any tranny you want, from heavy duty T5's and there newer versions, 6 speeds, bullet proof AOD's (very expensive) to just about any combo of C4 or C6 transmission type you want.
good luck
Rgds
Mike
Old Jul 14, 2008 | 12:46 PM
HT32BSX115's Avatar
HT32BSX115
Howdy,
I think you would be happy with an automatic. If you do an automatic. You should go to an AOD since you'll get a pretty tall over drive which will make your truck a pleasure to drive on the highway.
If you want to tow something with it you could consider an E4OD. It's a pretty strong trans. (I'm putting one in my 55 F-600....pics in my gallery.)
Cheers,
Rick
Old Jul 14, 2008 | 07:16 PM
havi's Avatar
havi
I'll have the Roast Duck
I vote for the 70's 3 speed manual with a floor shift conversion, if you have a 3.25 rear gear. My '74 f100 had that combo and it was a blast! Then again, back then gas didn't cost a whole lot.
Old Jul 14, 2008 | 07:31 PM
85e150's Avatar
85e150
Oh, I think a Powerglide would be best....
(Next poster will suggest and in & out box....)
(see the trend?)
Old Jul 14, 2008 | 07:37 PM
havi's Avatar
havi
last poster would have to recommend a direct drive, lol.
Old Jul 14, 2008 | 08:29 PM
55fordtruck's Avatar
55fordtruck
I just picked up a 4R70W today. I got tired of changing gears. Now I just need to order my wiring harness and computer control.
Kevin
Old Jul 15, 2008 | 01:31 AM
85e150's Avatar
85e150
I guess a clutch-only would be one step down from the in/out box.
4R70W huh? That ought to work. Good luck & Happy Motoring!
Old Jul 15, 2008 | 11:18 AM
BFOOTER03's Avatar
BFOOTER03
Still think I am going to go with a manual trans. Have considered the AOD but really like runnng through the gears of my current 3 on the tree with no OD. Gotta figure a 5 speed will be even more fun!!!
Mike you by chance have a company that offers the kit to modify/convert the T5 shifter?
Thanks to all for the help.
Old Jul 15, 2008 | 04:36 PM
Holmsey's Avatar
Holmsey
I have a T5 in my 302 powered 55 F100, no problems with the std location of the shifter. I did fit a Pro 5.0 short throw shifter linkage though and then just made up a shifter, with a bend round the seat front, works ace.
Old Jul 15, 2008 | 07:15 PM
85e150's Avatar
85e150
T 5 and more and more and more:
Modern Driveline - T5 / TREMEC TKO Transmission Conversion - Swap your Ford Mustang, Falcon, Cobra, Hotrod into Overdrive! Performance Parts
They have had used trans for sale in the past, but none showing the last few times I checked.
Old Feb 18, 2023 | 07:32 PM
69f100longbed360's Avatar
69f100longbed360
How about a M5R2 from an 88-11 F150?
Old Feb 18, 2023 | 08:15 PM
EBEAR's Avatar
EBEAR
This is a 15 year old thread so it's probably been looked after .
Old Feb 18, 2023 | 08:39 PM
69f100longbed360
i saw that and the reason I replied is because no one said it in this thread and this thread shows as one of the top results if you google search “manual transmission options for 302 Windsor”
Old Feb 18, 2023 | 10:49 PM
85e150's Avatar
85e150
M5od is OK but requires a juice clutch.
dogstar
16
Dec 1, 2010 06:35 PM
glmule
Jul 30, 2010 11:48 AM
ba 302
Mar 21, 2003 09:44 PM
wray
Nov 13, 2001 10:51 PM
berso
Feb 4, 2000 08:33 AM
