Sorry to post about the same problem but I need to try and get this fixed today. After my truck sits over night it will not start in the morning. If I jump it off it will start fine and run fine. And the volts will slowly come back up if I drive it for awhile and it will start after sitting for a couple of hours. But after sitting over night it will not start, the engine turns over and gets weaker and weaker. Is this a battery or alternator problem? Should I take both to get checked? If it's the alternator where is an acceptable place to buy one for these trucks? Also, what should I expect to pay for an alternator? I guess I should hope it's the battery or batteries?
disconnect the batteries and load test them, if they check out then you need an ammeter hooked inline with the batery cable to check for parasitic draw, if you verify the darw then start by disconnecting the alternator, then work your way through the fuse box removing each fuse one at a time until the draw stops, when it stops that is the circuit killing your batteries, diag from there.
probably need new batterys take them out and have them load tested, even if they come back on the low side of ok replace them, these trucks take alot to start
3yr old Autozone batteries. I'm gonna say that's the problem. Your gauge comes back up because the alt finally starts catching the batteries up. But they are discharging over night. Get you some interstate batteries and call it quits. If you don't have the glow plug relay on an switch, these trucks are hard on batteries. I find spending the money on good batteries is worth it for us. But by all means, have them load tested.
Had the same problem. My truck had Duralast batteries when I bought it. Began having to jumpstart it after sitting overnight. Took the batteries out and to Advance. Both batteries were bad. Mine were dated 11/06 and 2/07. Advance gave me two new ones free of charge even with no receipt. 3 years replacement warraty. Finally, something wrong with my truck I could fix for free.
