NEed quick advice please
Old Jul 12, 2008 | 10:04 AM
tndiesel's Avatar
tndiesel
Sorry to post about the same problem but I need to try and get this fixed today. After my truck sits over night it will not start in the morning. If I jump it off it will start fine and run fine. And the volts will slowly come back up if I drive it for awhile and it will start after sitting for a couple of hours. But after sitting over night it will not start, the engine turns over and gets weaker and weaker. Is this a battery or alternator problem? Should I take both to get checked? If it's the alternator where is an acceptable place to buy one for these trucks? Also, what should I expect to pay for an alternator? I guess I should hope it's the battery or batteries?
Thanks!
Old Jul 12, 2008 | 10:13 AM
c00nhunterjoe's Avatar
c00nhunterjoe
disconnect the batteries and load test them, if they check out then you need an ammeter hooked inline with the batery cable to check for parasitic draw, if you verify the darw then start by disconnecting the alternator, then work your way through the fuse box removing each fuse one at a time until the draw stops, when it stops that is the circuit killing your batteries, diag from there.
farmert's Avatar
farmert
How old are rhe batterys? My vote says the are getting old and tired. I would have them chrcked.
Old Jul 12, 2008 | 10:41 AM
tndiesel's Avatar
tndiesel
They both have the date 9/05 on them and they are duralast batteries. I think they were treated poorly before I bought the truck.
Old Jul 12, 2008 | 10:22 PM
IDMooseMan's Avatar
IDMooseMan
Three-year-old batteries and you think they were treated poorly before you bought the truck? I think the batteries should be replaced regardless.
Still check for a parasitic draw, but make sure your batteries are NOT the problem, first.
Have the alternator checked, too. These are probably the most likely causes. Once you verify these items are working properly, you can go from there.
Old Jul 13, 2008 | 12:00 AM
884x4broncoII's Avatar
884x4broncoII
probably need new batterys take them out and have them load tested, even if they come back on the low side of ok replace them, these trucks take alot to start
Old Jul 13, 2008 | 02:46 AM
RubberDuck's Avatar
RubberDuck
3yr old Autozone batteries. I'm gonna say that's the problem. Your gauge comes back up because the alt finally starts catching the batteries up. But they are discharging over night. Get you some interstate batteries and call it quits. If you don't have the glow plug relay on an switch, these trucks are hard on batteries. I find spending the money on good batteries is worth it for us. But by all means, have them load tested.
Old Jul 13, 2008 | 07:26 AM
KiotiLee's Avatar
KiotiLee
Had the same problem. My truck had Duralast batteries when I bought it. Began having to jumpstart it after sitting overnight. Took the batteries out and to Advance. Both batteries were bad. Mine were dated 11/06 and 2/07. Advance gave me two new ones free of charge even with no receipt. 3 years replacement warraty. Finally, something wrong with my truck I could fix for free.
billingslm1
May 29, 2013 07:38 AM
WilPower
15
Dec 18, 2012 07:41 PM
Farmboy1285
17
Jan 15, 2011 12:37 AM
bandlgeorge
16
Feb 8, 2009 01:08 PM
cbrew
May 10, 2007 06:38 PM
