vent removal
Old Nov 11, 2001 | 12:28 PM
Bronco79's Avatar
Bronco79
vent removal
Anyone know how to remove the dash vents from a 78 ford f-150 without breaking the tabs that hold the vents in?
Old Nov 12, 2001 | 04:06 AM
karljay's Avatar
karljay
vent removal
I'm pretty sure these are the same as the F150/250 trucks, the Ford manual says to use an ice pick or small flat screwdriver to pull the tabs in from the inside of the vent and then wiggle the vent out. You can also remove the inside louvers with a thin screwdriver at the top & bottom and that might help to get to the tabs.
If you think they'll crack, a hair dryer will help to warm the plastic and that helps to prevent cracking.
Old Nov 14, 2001 | 01:11 PM
Bronco79's Avatar
Bronco79
vent removal
Thanks. I'll try to be more careful. It seems those things are hard to get out!
Old Nov 16, 2001 | 12:44 PM
erstanfo's Avatar
erstanfo
vent removal
pburress
Oct 15, 2015 08:30 AM
beartracks
Jul 24, 2015 08:24 PM
fx4local3284
2004 - 2008 F150
Nov 15, 2010 08:54 PM
ag-ford-4x4
Oct 21, 2010 07:12 PM
lance65
Jul 11, 2010 06:02 PM
