I want to change all of them actually, the one to the right of the radio was just changed but I think they installed a used one so I'll probably change it anyway. The one that is broke is on the drivers side closest to the door. Thanks. Coach
if the dash is like my 07 it is really easy. you have to pull the face of the dash off. I start at the driver side, grab the dash where it turns down at the vent and pull out. then you will follow the dash line over to the third vent by pulling at each keeper.
You will want to lower your steering wheel all the way down. After you get every thing unplugged then you can see the screws on the back of the vents, remove the screws and you can take the vent completly apart.
I was going to put mine in the dish washer to clean but decided to use armorall and a toothbrush.
