351w head bolts?
Old Jul 10, 2008 | 08:45 PM
Sandman1991's Avatar
Sandman1991
351w head bolts?
was wondering if you can reuse the head bolts? (i assume not) what is the torque specs and sequence?
Old Jul 10, 2008 | 09:22 PM
jason85351's Avatar
jason85351
you can but i reccommend using arp head bolts and put arp moly lube on them. The torque sequence, standing on the opposite side of the head you first snug the bolts from the middle then the next two on the left then the two to the right of the middle then all the way left again then all the way to the right. then you torque them to the specs of the heads with the type of lube you use. with moly it's 95 ft lbs
Old Jul 10, 2008 | 09:51 PM
Sandman1991
so pretty much from the center out k thanks
Old Jul 12, 2008 | 02:10 PM
doug1222556's Avatar
doug1222556
I'd at least get new OEM or OEM replacement headbolts- unless you already have upgraded head bolts like ARP's- they can be re-used a dozen times.
pchelp
28
Jun 14, 2017 03:48 PM
7.399
Aug 12, 2016 11:15 AM
mxer0022
Apr 12, 2016 07:28 PM
john fin
Jun 20, 2008 05:19 PM
wilsonriverfisher
Escape & Escape Hybrid
Jun 13, 2008 08:17 PM
