hey bro i need some lift help i took my truck in to the ford shop and they are telling me that all 6 of my shocks are leaking i have a 6 inch dr lift
so can i put fox shocks with this lift or just put new dr shocks on it
and im all so thinking i want to go to 8ich already have the tires to do it and want to no if i replace them can i put them on the new lift
thanks for the help
and what kind of price can the total 8 system cost with everything i would need and fox or saw shocks and do you think i should just go to 8 b4 i put the shocks on
and to do those shocks what do i need to do if anything to run them
If you have a 6" spring lift you can stack the 3" hanger kit on it to make 9". You might need a different track bar or bracket and a further drop pitman arm to make it all work, but it would allow you to keep your current springs.
As mentioned you can do the 3" hanger shackle in the front and either a block in the rear or a set of spring if you currently still have the stock rear springs.
I would definitely recommend a adjustable trac bar.
Box kit (pitman arm, trac bar bracket, etc..) is the same.
SAW is Sway-A-Way.
Best shock is subjective.
Best shock for the money currently is Icon.
King would be my next choice for an upgrade and you have the option of customizing them with custom anodizing, braided ss lines, etc..
