Sponsored by: Real Truck
calling dc
Old Jul 10, 2008 | 04:22 PM
conman3300's Avatar
conman3300
calling dc
hey bro i need some lift help i took my truck in to the ford shop and they are telling me that all 6 of my shocks are leaking i have a 6 inch dr lift
so can i put fox shocks with this lift or just put new dr shocks on it
and im all so thinking i want to go to 8ich already have the tires to do it and want to no if i replace them can i put them on the new lift
thanks for the help
Old Jul 10, 2008 | 08:12 PM
DCSpecial's Avatar
DCSpecial
You can put Fox, King, SAW, etc on it.
If your Shocks are leaking, contact the place you bought them from as they should be able to warranty them out.
The shocks for a 6" lift are shorter than the ones for the 8" lift.
Old Jul 10, 2008 | 11:31 PM
conman3300's Avatar
conman3300
what is saw shock iv never heard of them
and what is the best shock out for the 6 and 8
and what kind of price can the total 8 system cost with everything i would need and fox or saw shocks and do you think i should just go to 8 b4 i put the shocks on
and to do those shocks what do i need to do if anything to run them
Old Jul 10, 2008 | 11:33 PM
conman3300's Avatar
conman3300
thanks dc for the help
Old Jul 11, 2008 | 01:18 AM
conman3300's Avatar
conman3300
its a 2001 f350 cc if that matters and which fox or saw shock should i get cuase theres so many choices to get thanks
Old Jul 11, 2008 | 01:45 AM
cartmanea's Avatar
cartmanea
If you have a 6" spring lift you can stack the 3" hanger kit on it to make 9". You might need a different track bar or bracket and a further drop pitman arm to make it all work, but it would allow you to keep your current springs.
Old Jul 11, 2008 | 07:35 AM
DCSpecial's Avatar
DCSpecial
As mentioned you can do the 3" hanger shackle in the front and either a block in the rear or a set of spring if you currently still have the stock rear springs.
I would definitely recommend a adjustable trac bar.
Box kit (pitman arm, trac bar bracket, etc..) is the same.
SAW is Sway-A-Way.
Best shock is subjective.
Best shock for the money currently is Icon.
King would be my next choice for an upgrade and you have the option of customizing them with custom anodizing, braided ss lines, etc..
ac_racing
Modular V10 (6.8l)
Aug 30, 2012 01:10 AM
FordFanFrits
Jan 25, 2010 07:11 PM
semcderm
Aug 29, 2008 03:30 PM
emmagator
Feb 25, 2008 08:16 PM
zstyle01
Feb 20, 2007 10:37 PM
