Squeaking from Engine
Old Jul 9, 2008 | 07:14 PM
patrick_q's Avatar
patrick_q
Ok, so I've got a 99 Ford Explorer that has developed a squeaking noise coming from the engine. It is not the belt or any of the accessories attached to the belt because it makes the noise with the belt off.
We've put a steth on most everything we can think of and cannot pin point the problem. The car drives and runs fine, there is no performance issue.
The next thing we are going to try is changing the oil and running it with 4 quarts oil and 1 quart Marvels Mystery Oil to see if that can solve the problem.
Otherwise I'm at a complete loss.
Anyone have any ideas?
Old Jul 9, 2008 | 09:37 PM
steve(ill)'s Avatar
steve(ill)
if its internal i might guess a timing chain adjuster?
Old Jul 10, 2008 | 09:02 AM
marragtop's Avatar
marragtop
Does the noise vary with the RPMS, and does putting the trans in gear have any impact on it?
Old Jul 11, 2008 | 04:29 AM
460's Avatar
460
What engine? And is it a squeaking noise or more of a chirping noise?
My 5.0 was making a loud intermittent chirping noise when the cam position synchronizer was bad.
15
Jan 25, 2017 03:41 PM
riggz
Dec 8, 2008 05:29 PM
Jose A.
Aerostar
26
Nov 5, 2006 04:20 PM
franklin411
13
Oct 29, 2003 07:30 PM
swenson
1978 - 1996 Big Bronco
Jul 19, 2001 07:19 PM
