1978 - 1996 Big Bronco
Engine squeaks until thoroughly warmed up
Old Jun 21, 2001 | 06:36 PM
swenson's Avatar
swenson
My 302 in my 95 Bronco squeaks until the engine is completely warmed up and then the noise disappears. I thought it would disappear in the summer warm weather but it hasn't. Is it the serpentine belt squeaking, and if so, is there any way of fixing it? The truck is too beautiful to be squeaking all the time, it really takes away from it.
Old Jun 21, 2001 | 11:15 PM
whomrig's Avatar
whomrig
Try spraying some wd40 on the belt while it is squeaking. If the squeak goes away, replace the belt.
Wayne
e-mail
http://home.pacbell.net/whomrig
Old Jun 26, 2001 | 06:55 PM
91brawnc's Avatar
91brawnc
I had the same problem with my '91 and from what I've read there's an inherent problem that I figured they would've fixed by '95. It turns out that the stock water pump is misaligned. Mine will squeal when it rains or is humid outside. I did try WD40 but it only worked temorarily. There are anti-sqeak lubricants for belts at you local auto shop.
Old Jun 27, 2001 | 07:08 AM
AlM's Avatar
AlM
Also, suggest using a piece of garden hose or gift wrap cardboard tube (we have a nurse's stethoscope) to probe around and listen to isolate that noise..be careful of the fan & belts/alt fan tho!
also, besides the belt, check for noise from the serpentine belt's idler pulley; seems that a lot of folks replace this idler when they replace the belt. there is a tsb on this:
http://www.nhtsa.dot.gov/cars/problems/tsb/servicemmy.cfm
Old Jul 19, 2001 | 03:01 AM
95BroncoMan's Avatar
95BroncoMan
I have a 95 Bronco w/302, and I had that same exact problem, the fix for it was a new idler pully. The one that was there had developed a flat spot on it, and when it touched the belt it would whistle untill it heated up, and softened up.
Old Jul 19, 2001 | 07:19 PM
rwjr's Avatar
rwjr
patrickj20
Jan 31, 2015 07:50 AM
LCA078
Jan 18, 2015 10:05 AM
broncoderek
Oct 28, 2014 02:54 PM
88_F0RD
13
Apr 4, 2014 04:55 AM
Ed in Maine
Jan 14, 2014 09:59 PM
