I believe the original Throttle Kicker device was in place to let the carb fully close when the
engine was shut off in order to ensure it stops running (doesn't diesel).
But my first suspicion is the carb; you should not be able to turn the idle mixture adjustment
screws all the way in with there being no difference in how the engine idles. Something is
wrong there.
This carb was on a running 428 before I rebuilt it. It really does seem like a vacume leak, because the idle mix screws do not change anything.
I put a gasket under the air cleaner stud, and got the secondary opening a previous problem i figured out. I also switched the coil, and pickup coil in the dizzy related wiring.
I will definatly try to use some starting fluid to check for leaks.
With Egr removed has anyone ever had their dizzy recurved??
Well, in my experience, vacuum leak or not, fully closing the two idle adjustment
screws will result in the engine dying. I've created intentional vacuum leaks and fiddled
with my carb to no end in order to pass the emissions tests.
I believe recurving the distributor is necessary only if your engine is run by a computer.
But I'm not entirely positive on this, it's just a random bit of info I picked up over time.
I was fiddling around with my carb some more and I can close the secondary shaft a little and it idles down just a hair still not low enough, when the secondarys open back up it doesnt close all of the way. It must be sticking internally like the butterflys. When I close the shaft and turn off the key it still diesels.
I dont have any starting fluid so ill try that tommorrow when i pickup a can.
The secondaries normally don't close tight. If they did they might stick. You might have a vacuum leak on the underneath sideof the manifold, along the bottom of the runners. Do you have any oil leaks/burning?
