High idle
Old Jul 23, 2015 | 04:57 PM
Beardad82's Avatar
Beardad82
High idle
I've got a 92 F-150 with a 4.9L that I just finished putting a new set of lifters and pushrods in. Got it back together and turned the key and cranked like a dream but the idle is way high. I've unplugged the IAC and nothing changed as well as back the idle adjustment screw almost completely out. All my vacuum lines are in good shape. Anyone have any input?
Old Jul 23, 2015 | 07:23 PM
rla2005's Avatar
rla2005
Put the throttle stop screw back. You have a vacuum leak. Replace the vacuum lines. One or more broke, Very common problem.
Old Jul 23, 2015 | 09:14 PM
Beardad82's Avatar
Beardad82
I've checked all of my vacuum lines and they are all solid. If I unhook them the rpms go up even more.
Old Jul 23, 2015 | 09:22 PM
rla2005's Avatar
rla2005
Did you plug the ends?
The problem you describe is very common with broken vacuum lines. The vinyl tubing gets VERY brittle with age. Visual inspection may not work very well.
Old Jul 23, 2015 | 09:42 PM
Beardad82's Avatar
Beardad82
I did plug the ends with my thumb one at a time. I'll go back over them again when I get a chance
95f150short
Aug 7, 2018 05:40 PM
HuntingRat
24
Dec 1, 2017 12:22 PM
Chris Gathof
Jul 8, 2017 05:27 PM
chessman21
Feb 12, 2011 08:32 AM
