batteries not charging - help pls
Old Jul 9, 2008 | 11:49 AM
fear_nothing's Avatar
fear_nothing
I've been fighting electrical issues with my X for about two months, its manged to leave me stuck in a major intersection at rush hour.
So I've replaced both batteries and alternator, I just replaced the alternator Sunday. Prior to the alternator replacement I measured
the voltage at each battery, it was low measuring 11 volts. After the the alternator was installed, the voltage immediately jumped
back to 12 volts. The voltage was measure at both batteries and alternator, no variance at all.
However today the battery light came back on. Should I replace the cables now?
Specs: 04 | Diesel | 96,000
Old Jul 9, 2008 | 12:32 PM
undrh2o's Avatar
undrh2o
Did you have the system tested prior to replacing the batteries & alternator? It could be the cables or something pulling the battery voltage down (stuck relay, solenoid, etc...)
If it wasn't tested prior have someone run a routine on it (Advance, Auto Zone)
Old Jul 10, 2008 | 06:08 AM
DSMMH's Avatar
DSMMH
The voltage should be between 13.5 to 14.5 volts with the motor running. If less, you probably have a serious current draw on the system. I would get an AMP meter, disconnect the positive terminal of either battery and put it in line with the battery post and the cable. This would be done with the engine off and the key off. From what you are saying, it should read about a 3 to 5 AMP draw. Then I would start pulling fuses then the relays one at a time until the AMP meter draw drops to below about .5 AMPs. If pulling the fuses and relays does not reduce the current draw, then you possibly have a short in your power distribution to the fuse/relay panel.
DSMMH
1976highboy390
Feb 6, 2015 03:44 PM
greg_8507
Jan 20, 2014 03:43 PM
aj3501
Jul 31, 2012 11:41 AM
hoganlo
1997 - 2003 F150
Mar 3, 2012 03:33 PM
mxfam4x4
15
Mar 5, 2008 10:38 AM
