up pipe flanges
Old Jul 8, 2008 | 09:02 PM
Superduty krazy's Avatar
Superduty krazy
up pipe flanges
I've read all kinds of info just woundering if theres any other tips you guys might have besides that i should be doing bellowed uppies...Cant afford them due tu the price of fuel....i have all the o rings that i need for the pedestal I want to do the epbv delete at the same time anyone know the size of the plug i need???
Old Jul 8, 2008 | 09:08 PM
megawatt00's Avatar
megawatt00
Here are some part #'s for the dounuts on the up pipes. The 2nd on is for a small block chevy and they are a tad bit bigger.
(Ford) F4TZ-6K854-C
(Napa) F17250. Up-pipe donuts for Small Block Chevy V8
Old Jul 8, 2008 | 11:42 PM
rebelchevy02's Avatar
rebelchevy02
I think beans diesel has "leak proof" donuts.
Old Jul 9, 2008 | 12:20 AM
mongo75's Avatar
mongo75
Jeez, good luck getting the damn things apart- when I finally get around to my up pipes, I'm pulling the tranny, hell maybe even the cab.....
Old Jul 9, 2008 | 08:36 AM
mueckster's Avatar
mueckster
I only have the instructions for the OBS trucks. The plug for the shaft hole is shown to be 20mm. I believe they are the same size as the '99-up. I ended up doing the non EBPV pedestal and outlet housing.
Old Jul 9, 2008 | 09:02 AM
sideshow's Avatar
sideshow
are your's leaking now? i ask, because it seems everybody thinks they should replace them when they have the turbo out. i've had my turbo out several times, and never even gave a thought to mine, since they dont' leak. absolutely no soot anywhere. i can't see how pulling the turbo is going to make them leak either, but i've read where some have said to expect a leak soon. i don't buy it. the first time i pulled the turbo, i had some trouble with the connection at the collector and v clamp, but some copper anti seize solved that. the next time, the v clamp literally fell off, and the turbo/collector connection separated with no effort. i can see if you have a leak that this is a good time to repair, but dont' understand if it isn't leaking. i'd rather not open up a good sealing connection for fear that it would leak when i was done. jsut my .02.
Old Jul 9, 2008 | 04:10 PM
03F2507.3's Avatar
03F2507.3
Im in the same situation. I am having my turbo replaced and was thinking of changing the up pipes but mine DONT leak. My mechanic told me to leave them alone. Is there a "good" chance that by removing the turbo the seals will loosen up on the up pipes?
Old Jul 9, 2008 | 04:57 PM
Superduty krazy
mine definatly leak badly i can hear them...not to mention when i have a load on and i'm workin the truck they really leak badly
Old Jul 10, 2008 | 01:46 AM
rebelchevy02
Not necesarily. The only real issue with that, is lining up the dimple on the "babies butt" to were it sits on the turbo, and that normally is easy to tell, with high egts, low boost. Up pipe leakes are usually seen, by looking from the ground up, with a flashlight, at were they connect at the upper Y. Those joints are the main leak area.
Old Jul 10, 2008 | 06:00 AM
Superduty krazy
well i got it all done at 2am this morn....my upies don't leak but at the manifold it does i will have to tighten it more and tap them with a hamer
Old Jul 11, 2008 | 12:04 AM
mongo75's Avatar
mongo75
My damn right up pipe leaks "so bad" that the entire right side undercarriage is coated in soot. I think I'll do the late 99 bellows and bb turbo when I get back from Iraq in Oct '09
High76boy
May 30, 2014 12:43 AM
*2fords*
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Dec 10, 2010 10:21 AM
AKCarl
16
Aug 31, 2007 09:11 PM
powerstrokeddiesel
17
Jun 29, 2007 05:03 PM
92 f150300six
Jan 19, 2004 12:06 AM
