actuator 98' ford explorer drivers side-intermittent issues
Old Jul 8, 2008 | 10:25 AM
biggyg2's Avatar
biggyg2
I recently replaced the drivers side actuator on a 98 Ford Explorer Sport.
The problem previously was with the door not unlocking without some manually force (pull the door **** up while trying to unlock it.). The problem was intermittant.
Well, the actuator was replaced and it still is a issue some of the time.
I've read posts on the linkage needing grease but there are very little moving parts.
Any suggestions on what to check next?
Gavin
Old Jul 9, 2008 | 10:17 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Thread moved to the Explorer section
Old Jul 9, 2008 | 04:43 PM
BJWinter's Avatar
BJWinter
This sounds like another issue with the door handle springs. There is a small spring as part of the door handle assembly which holds pressure on the handle itself. There are a number of threads in this forum discussing it, but here's a good one with a relatively straight forward DIY fix. I haven't actually torn into mine to try it yet, but it seems relatively straight forward.
https://www.ford-trucks.com/forums/7...ring-help.html
Good luck!
ztodd377
Dec 12, 2014 01:44 PM
bluef72
Oct 17, 2013 11:26 PM
vf150
1997 - 2003 F150
Aug 9, 2013 02:33 PM
Greek 350
Mar 27, 2012 07:28 AM
bob_m10
Electrical Systems/Wiring
Sep 14, 2008 01:15 PM
