Question on RPMs
Old Jul 15, 2008 | 12:44 PM
  #31
Zephyr's Avatar
Zephyr
Sounds to me like either your trany isnt shifting into overdrive or the torque converter is slipping
Old Jul 15, 2008 | 12:59 PM
  #32
twags6's Avatar
twags6
Originally Posted by dannyboy7.3
Hey Everyone,
I did a manual test last weekend and I do indeed have the 3.73 gears just like the tag and door sticker say.
Any ideas why my MPH is so low at 2000 RPMs? Everything is running just fine (as far as i know with my limited knowledge of diesels).
Thanks
Sorry if you posted this already, but what size tires do you have on the truck? Stock is LT265/75/R16. If it had larger tires on it at some point, the speedo might have been recalibrated for them.
Old Jul 15, 2008 | 01:23 PM
  #33
WILDMAN_Stroker*7.3's Avatar
WILDMAN_Stroker*7.3
F350_6
Thanks for the link for the manuals, tried to rep point you but I need to spread around.
Old Jul 15, 2008 | 01:30 PM
  #34
Markadeck's Avatar
Markadeck
Gone, but not forgotten
I've been mulling this one over and if he did my instructions to a tee, your guess is probably a good one. It makes no sense to me, other than maybe slippage in the tranny, but they don't slip for long and keep on going. The Energizer bunny they ain't.
Old Jul 15, 2008 | 02:35 PM
  #35
dannyboy7.3's Avatar
dannyboy7.3
It has the stock wheel/tire on it LT265/75/R16. I had it in the shop for an oil change at the beginning of the year before I started changing my own. Asked about the speedo and they flashed the PCM a couple times with the same results. Yes, it is dropping into overdrive.
Old Jul 15, 2008 | 03:54 PM
  #36
Markadeck's Avatar
Markadeck
Well then, if it is nothing mechanical or electrical in you systems then either your tach or speedometer is off. Another simple do it yourself test. Stopwatch, measured mile, perfect 60 mph for the entire mile. How many seconds? If it is not EXACTLY 60, something is wrong with your speedometer.
Old Jul 15, 2008 | 04:16 PM
  #37
danskool's Avatar
danskool
Go Bills !
How does the rpm gauge gets its signal? I Borrowed a scangauge and it told me the RPM and it matched what the gauge was telling me.
62 @ 2000. RPM. Sure does sound like 4:10. I know you mechanically checked it but it still seems like 4:10. OR how ever it gets the rpm signal is screwed up.
I would believe your GPS. mine is dead on.
Could someone swap out the gears and not the tag?
For me. And checked it again today.
373 gears 265 tires bald.
70=2100
68=2000
65=1900
Old Jul 15, 2008 | 04:20 PM
  #38
Markadeck's Avatar
Markadeck
70=2100
68=2000
65=1900
He said he did it mechanically, and that's very accurate and foolproof. I know y'all of the digital age find this hard to believe, but the method I posted will work no matter what size your tires are. It will give you your exact final drive ratio, simple as that. I would say it's even more accurate than a GPS. That applies to the 60 seconds or the laying on your back and counting revolutions. 5,280 feet at EXACTLY 60 mph results in 60 seconds, and I did not even finish high school.
Old Jul 15, 2008 | 04:29 PM
  #39
Markadeck's Avatar
Markadeck
I don't know where the tach pickup is, but if I were to guess I would say the CPS. If you were to take off your serpentine belt and see if the tach still works that would pretty much tell you that's where it is.
Old Jul 15, 2008 | 05:36 PM
  #40
MR5x5's Avatar
MR5x5
Pretty good claculator. It's all mechanical linkages, so it can be exactly determined. Check what you are seeing against calculated values.
4R100 w/3.73: 2000 RPM = 71 MPH
Gear Ratio Calculator
Turbo_Whistler
16
Jul 29, 2022 11:08 AM
Vin Man
Apr 24, 2012 05:29 PM
spud57
May 30, 2010 06:18 PM
bigreave
Apr 10, 2004 09:09 AM
oldfordsidestep
Feb 2, 2001 03:15 PM
