I need VIN decode help
Old Jul 7, 2008 | 01:08 PM
craig at ojo's Avatar
craig at ojo
Hi everyone,
I am trying to build one truck out of two and I need to decode the VIN's on both trucks so I can request a VIN inspection.
I mainly need to Know the year on both Trucks.
1st one F10YR833390
2nd one F10YR830219
Also, any info on how to decode will be helpful so I can do it myself in the future
Thanks,
Craig
Old Jul 7, 2008 | 01:20 PM
camperspecial65's Avatar
camperspecial65
Both are 1966 F100s with 352 and built in San Jose, Ca in March 1966...the March build sequence starts at 830,000 btw
- cs65
Old Jul 7, 2008 | 01:33 PM
craig at ojo
Thanks! I appreciate the help.
Craig
Old Jul 7, 2008 | 07:07 PM
Customcab's Avatar
Customcab
Craig; post the rest of the data plate info and we can decode trans; axle, color & body type as well.
Mitch
Old Jul 8, 2008 | 08:33 AM
craig at ojo
Here's the rest of the information
Here is the rest of the tag info for both trucks.
F10YR833390
COLOR M
BODY B81
TRANS G
AXLE 17
172HP @4000
DSO 71
F10YR830219
COLOR 8M
BODY U81
TRANS A
AXLE 17
172 @ 4000
DSO 75
Thanks again. I am going to build one truck out of the two. one has been rolled. I have a separate 390 and a c-6 that I will rebuild and use.
I'm thinking that the 8m color is a two-tone scheme so thats what i'll follow.
Craig
Old Jul 8, 2008 | 09:26 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
F10YR833390
COLOR M
BODY B81
TRANS G
AXLE 17
172HP @4000
DSO 71
Craig
I'll do one at a time...makes it easier...at least for me.
F10 = F100 2WD / 5,000 lbs. GVWR (Gross Vehicle Weight Rating)
Y = 352 2V
R = San Jose CA Assembly Plant
833390 = 1966
M = Wimbledon White
B81: B = Medium Blue Crush Vinyl & Medium Blue Cody Pattern Woven Plastic / 81 = 81B Custom Cab
G = MX Cruise-O-Matic
17 = Ford 9" / 3.25-1 / non Limited Slip / 3300 lbs. Rear Axle Capacity
172 NET HP @ 4000 RPM
71 = Los Angeles (SoCal) Ford District Sales Zone Office, were the original selling dealer ordered the truck from.
Old Jul 8, 2008 | 09:36 AM
NumberDummy
F10YR830219
COLOR 8M
BODY U81
TRANS A
AXLE 17
172 @ 4000
DSO 75
Y = 352 2V
R = San Jose Assembly Plant
830219 = 1966
8M: 8 = Springtime Yellow / M = Wimbledon White
U81: U = Parchment Crinkle Vinyl & Black Rosette Vinyl - Bucket Seats / 81 = 81B Custom Cab with the Ranger Package
A = New Process 435 4 Speed Transmission
75 = Phoenix AZ Ford District Sales Zone Office
Decode source...Uh....mostly from memory....I've decoded over 600 VIN's on FTE.
All the info will be found in the: 1964/72 Ford Truck Parts Catalog / Available on a CD from hipoparts.com / Also sold on ebay for around 22 bucks.
Old Jul 8, 2008 | 05:05 PM
camperspecial65
If the truck that has the blue seat is in good shape, give a holler...Im also after a few other odds and ends...a firewall pad among them...Let me know when you can.
- cs65
Old Jul 8, 2008 | 05:14 PM
NumberDummy
Originally Posted by camperspecial65
If the truck that has the blue seat is in good shape, give a holler...Im also after a few other odds and ends...a firewall pad among them...Let me know when you can. - cs65
You have a thing for that firewall pad, doncha?
Geez, the truck doesn't run, it's rusted to all heck, fluids leak from every oriface, the carb chit the bed years ago, the interior is moth infested...the only holding the truck together is memory.
But ya just gotta have that firewall pad...
Sorry kiddo...I couldn't resist.
Old Jul 9, 2008 | 10:58 PM
craig at ojo
the seat - If it's the original - is blue with dark blue stripes on it. I haven't seen any tears in it but it has been out in the weather for several years. The truck sat in a friend's back lot with no glass in the cab (rolled over). I am presently using the seat in my '60 f-100 (the 60 seat is really trashed). I would trade it for another Bench seat in decent shape.
The firewall pad in the rollover is trashed. I am re-using the other cab so i need the firewall pad in it- sorry
Craig
Old Jul 9, 2008 | 11:03 PM
craig at ojo
Thanks for all the info, Number Dummy!
I assume it was white down to the bottom edge of the hood and yellow below that. that's how I'll paint it when I get it together. Still wrestling with NMMVD right now.
Old Jul 12, 2008 | 12:15 AM
camperspecial65
LOL....ya....carbs nearly back together...and no leaks means I can drive the sucker...lol...until I get the last couple of parts for the front end rebuild.
Firewall pad...ya...I HAD a perfect one...until my dearly departed and much beloved rottweiler stepped on it...it was only down for a minute too...that was around 10 yrs ago....nearly had one too last year...attached to a near clone of mine cept 1 year newer...wasnt fast enough returning with the dough (
- cs65
