09' Release?
Old Jul 10, 2008 | 08:28 AM
ArtsBest's Avatar
ArtsBest
ALL very good points. I've heard the 6-speed gets about 1-1.5 better MPG. If true all one has to do is the math on say, 100K, and calculate the actual value of buying an 08' w/o the 6-speed vs the price of a new 09' w/o the major incentives the 08's are offering. I bet the 08's win out every time.
Old Jul 14, 2008 | 07:52 AM
Bruteskeg's Avatar
Bruteskeg
i was reading in a buddys truck mag it was an add from ford for the new 2009 f-150 said that it would be commin out with a 5.0L 340hp motor ??? said that it has a longer stroke then the curent 5.4L and 4.6. just what i was readin anyone else hear about this.
Old Jul 14, 2008 | 08:23 AM
excaliber551's Avatar
excaliber551
I read in an article by Ford that the new 6 speed would improve MPG by .6 MPGs.
The real improvement will be the smoother shifting and power band improvement.
Old Jul 14, 2008 | 11:21 AM
ArtsBest's Avatar
ArtsBest
6-speed
.6 MPG isn't exactly mind boggling numbers now is it? FORGET the smoother shifting we need BETTER MPG in America.
Old Jul 14, 2008 | 11:45 AM
V8EXPLR's Avatar
V8EXPLR
Now the 1-1.5 you quoted was most likely reported somewhere and this gain may be true. With the 6spd providing .6 mpgs and a potentially more efficient 5.4L providing anywhere from .4-.9 mpg gain. So it could be reasonable, but have no factual basis to support this claim.
Old Jul 14, 2008 | 12:05 PM
Fosters's Avatar
Fosters
if that 5.0 has a longer stroke than the 5.4, I can see a 4000 rpm redline in it's future...
if anything, it should be a big bore 4.6... the stroke is ok on these, esp the 5.4, the small bore is what's choking these engines up, shrouding the valves unnecessarily..
let's hope for some dohc heads too... hey, we can dream, right?
Old Jul 14, 2008 | 03:34 PM
Big Bad's Avatar
Big Bad
The 5.0L is supposed to be a 3.6x" X 3.6x" roughly square engine, a mild "big bore-stroker" 4.6 with extended cylinder liners to keep the piston skirts in the bore at BDC. Heard that from 3 very reliable sources, and so it's very likely the case. Logic dictates it must be true as well, as it would be the most reliable method for achieving 5.0L from the 4.6. I know the 3.7" bore failed Ford's long-term durability tests, and I'm fairly certain a 3.75" stroke stock bore engine would as well.
All sources also said the 5.0L is a DOHC 4V design, not just for increased cylinder head flow but also for the ability to run Twin Independent Variable Cam Timing (TiVCT).
It is also supposed to achieve better FE than the 4.6 3V, which does pretty well itself. Latest rumors put the the 5.0L "Triton" at 360 Hp and 380-390 TQ and the PFI Mustang version anywhere from 400-425 HP and 360+TQ. DI is supposed to take the Mustang version up to 440 HP or more.
Unless wishy-washy management kills this engine, this will be the engine Ford should have made a long time ago.
Old Jul 14, 2008 | 03:39 PM
Fosters's Avatar
Fosters
hope you're right... add in direct injection (yeah right..) and that motor would be pretty stout in n/a form to begin with... add in 2 turbos and we'll be in business
Old Jul 14, 2008 | 03:44 PM
Big Bad's Avatar
Big Bad
Made some edits in my last post. 5.0 4V EcoBoost is codename Bobcat, 5.0 4V N/A codename Coyote. They are out there.
Old Jul 14, 2008 | 05:16 PM
Fosters's Avatar
Fosters
what's the codename for the dohc v10 based on that??
I can dream, can't I? :P
Old Jul 17, 2008 | 07:00 PM
Bruteskeg's Avatar
Bruteskeg
so dose that mean the 302 lives again in the next gen f150 or what ???
Old Jul 17, 2008 | 09:09 PM
SUPERDUTY_untouchabl's Avatar
Wow a ecoboost 5.0. That sounds bad a$$. I wonder if the will bring them out with the v6 ecoboost?
Old Jul 20, 2008 | 10:31 PM
  #28
Big Bad's Avatar
Big Bad
More like a 304 or 305.
Old Jul 21, 2008 | 08:51 PM
  #29
spyromike's Avatar
spyromike
has there been any update on the release date for the 2009 Ford F-150?
z31freakify
Mar 19, 2017 02:52 PM
NCMillwright
2009 - 2014 F150
13
Nov 1, 2016 12:41 AM
Fomoko1
21
Aug 16, 2010 04:00 PM
dsifer
2009 - 2014 F150
33
Jul 12, 2009 07:55 AM
Farmers Ford
Jan 21, 2003 10:20 PM
