CK-4 oil what Motorcraft is doing
Old 03-18-2017, 08:33 PM
z31freakify's Avatar
z31freakify
z31freakify is offline
Received 1,188 Likes on 816 Posts
Thought it was an interesting piece, so where does this leave us????
http://redirect.viglink.com/?format=...ft%0A%09%0A%09
Old 03-18-2017, 10:10 PM
Bluediesel250's Avatar
Bluediesel250
Bluediesel250 is offline
They say "some" engine components but don't specify which ones. I would be interested to know which components are failing
Old 03-19-2017, 11:40 AM
'74 Ford 250 CS's Avatar
'74 Ford 250 CS
'74 Ford 250 CS is offline
I've seen a couple of oil you tube videos talking about this, as well as, a couple videos. In all of them the language they use seems misleading. They say "Ford diesel owners not use CK-4 motor oil....". This statement makes it seem like this includes 6.9, 7.3, 6.0, 6.4, and 6.7. However, they only describe testing on the 6.7 only and not any of the other mentioned models. Since the first statement makes it seem like the issue includes all models , they only really mention one model of engine. It's poorly written but instills a possible issue. In my mind the other engines are totally different such as parts materials, etc. it would be nice to have some clarification instead of using phrase - "All Ford diesel owners..."
Am I missing a article saying the 7.3 is included?
Ford engineers are recommending that Ford diesel owners not use new CK-4 motor oils after company testing of some of those formulations revealed accelerated engine wear on some of the Ford 6.7-liter engine components in the engines they tested
Old 03-19-2017, 12:52 PM
BBslider001's Avatar
BBslider001
BBslider001 is offline
Read about it over on BITOG. There is a full thread that basically points to Ford as the problem and not the oil companies. What I mean is, run the new CK-4 with no worries. Ford is just being dumb.
Old 03-19-2017, 01:57 PM
Hussler's Avatar
Hussler
Hussler is offline
Some discussion on this subject on the 99-03 forums ...
https://www.ford-trucks.com/forums/1...k-4-is-ok.html
Old 03-19-2017, 02:52 PM
z31freakify
Oh I've read them, but still was curious at Fords no go on the CK-4 on 6.7 but not once did they mentioned older diesels. I'm not worry about the new standard in oil, I've used all kinds of oil on the fleet and if you maintain them I regularly we probably won't suffer any kind of engine failure. Besides the oil being used in the fleet for the past 2.5 years has been working great. theres an abundant supply of CJ-4 that most won't touch because of the "No name brand"
Pitcrw6
68
11-14-2020 12:14 AM
Traildust
89
09-29-2017 05:05 AM
TruckoffFord
1999 to 2016 Super Duty
13
09-09-2017 05:00 PM
speakerfritz
12-14-2016 11:56 AM
Studawg
24
11-26-2013 08:47 PM
Quick Reply: CK-4 oil what Motorcraft is doing
