Is it worth replacing bump-steer shock?
Old Jul 6, 2008 | 10:25 PM
bass3006's Avatar
bass3006
I recently replaced the shocks on my 2002 350 4x4, Ive got about 80 K on it. should I look at replacing the bump-steer shock on the front axel too? If so, it must be simple to do (should have looked before posting) and how much do they run, which brand should I get?
Old Jul 7, 2008 | 08:49 AM
nlemerise's Avatar
nlemerise
Very simple to check to see if you need a new one...pull two bolts and it will come off. Then see if the piston/valve assembly is working correctly. It should be stiff to both push and pull. Summit Racing has Rancho brand them and there are a number of other online shops that have Ranchos as well as many other fine brands.
Old Jul 7, 2008 | 08:55 AM
Pocket's Avatar
Pocket
My Rancho is a beefier version over the stock unit. However, I would not recommend it to anyone. It works fine, but after the first year, it looks like complete crap. It rusted out in no time. I can't wait until it goes out (or I smash it on a boulder), then I can get a different one.
Old Jul 7, 2008 | 09:00 AM
TN97STROKE's Avatar
TN97STROKE
I removed mine. Mine made the steering feel odd, then again I have never liked steering dampers. I have not had any ill effects from removing it.
Old Jul 7, 2008 | 09:08 AM
Mike F250's Avatar
Mike F250
I changed mine this past weekend. Stock one was dented, rusted and the shaft was bent. Got a skyjacker OEM shipped for $48 from topguncustomz on ebay. Fast shipping.
Glad I did it.
Old Jul 7, 2008 | 10:01 AM
nlemerise's Avatar
nlemerise
That's what happened to mine too...the finish sucks. I wonder if the valving could take powder coating heat?
Old Jul 7, 2008 | 10:28 AM
papadelogan's Avatar
papadelogan
Snowboard season cometh..
400* F for 20min+ I think would cook the crap out of it. In the past I've had good luck with a wirewheel, Rustoleom primer, and then Rustoleom paint. Let it hang out in the sun for a couple hours after each coat (2 primer, 3 color).
Old Jul 7, 2008 | 12:32 PM
smoky_diesel's Avatar
smoky_diesel
some aftermarket dampers will need some grinding on the factory bracket. Their effect is probably more noticeable with big tires.
Old Jul 7, 2008 | 09:45 PM
bass3006's Avatar
bass3006
These replies seem helpful (not that I would expect anything else from this site). I'm going to pull the bolts and check so see if it needs to be replaced.
Also as Pocket and nlemerise noted, I too have seen many Rancho brand products rust out quickly. Thanks
Old Jul 8, 2008 | 09:59 AM
tolmite's Avatar
tolmite
I put a rancho on less than a year ago and it's already starting to rust...
Old Jul 8, 2008 | 10:05 AM
That_Guy's Avatar
That_Guy
I just put some ranchos all around that I got a good deal on, sanded them and then hit them with a couple coats of rustolem black. They seem to be fine but only time will tell. I think they would be fine if painted properly but I wouldnt try powered coating, just dont think it would be a good idea.
Duellym
1947 and Older Ford Trucks
13
Mar 16, 2016 05:59 PM
rdinmv
Feb 24, 2014 05:07 PM
TexasTonka
Oct 27, 2012 05:16 PM
cummins cowboy
6.7L Power Stroke Diesel
21
Sep 3, 2011 11:51 AM
bansheeduner
Jan 9, 2008 10:42 AM
