Transmission question
Old Jul 8, 2008 | 07:10 AM
Olddog66's Avatar
Olddog66
I’ve heard stories from people about having problems after they had their transmission flushed. I was wondering if someone could give me some input. Should you just dump the pan fluid and torque converter fluid or should you have someone flush it? I have a 2001 F350 and it looks like I have a 4R100 transmission. The truck has 120K on it.
Thanks
Old Jul 8, 2008 | 07:22 AM
Diesel Man 03's Avatar
Diesel Man 03
If you never have had the trans flushed before pull the pan and change the fillter, the crud that's in there now might cause you problems after it gets stirred up with the flush, I wouldn't do it.
Old Jul 8, 2008 | 07:24 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I would go ahead and drop the pan, drain the TC, and install a new filter. I have the same year truck and thats what I did when I installed the BTS-VB.
Some will tell you to go ahead and flush the trans and cooler. Thats good too.
Good luck.
Old Jul 8, 2008 | 07:30 AM
Olddog66's Avatar
Olddog66
Do you have any idea about how much fluid I’ll need to get to replace the amount I’ll lose...are you including the torque converter? I’ve never done this so I need a little guidance. From what I can see there’s a plug you remove for the torque converter and I guess I’ll need the gasket and filter for the transmission pan...any suggestions on the best place to get this stuff.
Thanks
Old Jul 8, 2008 | 07:42 AM
mueckster's Avatar
mueckster
Try this link. it should answer most of your ???s. Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Old Jul 8, 2008 | 07:52 AM
Olddog66's Avatar
Olddog66
Great stuff thanks.
Old Jul 8, 2008 | 09:09 AM
kawajockie's Avatar
kawajockie
You can get a Tranny filter at Autozone, Pepboys, etc.
The filter comes with a gasket, but the ford one is resusable. I resused mine and it is fine.
Old Jul 8, 2008 | 10:16 AM
harleydude03's Avatar
harleydude03
it takes about 22qts. to change everything. pan, converter, lines, cooler.
BRay09
Dec 16, 2012 01:07 PM
danielharr79
1997 - 2003 F150
Mar 5, 2011 04:57 AM
gskershner
22
Jan 30, 2007 10:45 AM
IAMFORD
Jan 16, 2006 04:47 PM
gbeach
16
Jan 12, 2004 07:57 AM
