Blower Works on High Only
Old Jul 6, 2008 | 07:20 PM
FunkyFord's Avatar
FunkyFord
We have a 2000 Explorer EB with automatic temperature control. The blower works great on high but thats all. The temperature controller works fine. After searching this forum, it appears that I should replace the blower resistor module but I could not find anything definitive about its location for this specific model. I would greatly appreciate any advice on its location and specifics on how to get to it.
Thanks in advance!!!
Old Jul 6, 2008 | 09:44 PM
jasongt06's Avatar
jasongt06
look under the dash at the ac unit and you should see some electrical connections. Once you purchase the module you need you will be able to identify it.
Old Jul 6, 2008 | 09:50 PM
firepop5's Avatar
firepop5
lay on the passenger side front floor and look up under the glove box. look for the black air duct (heater duct). look for a 4 or 5 pin electrical plug. remove the plug, then the resistor block is screwed to the air duct with a small screw. air flow keeps the resistors cool.
Old Jul 7, 2008 | 09:08 PM
BJWinter's Avatar
BJWinter
I am having the same problem. Looking at autopartsgiant.com, there are three different resistor models for my 2000 Sport. Any suggestions on how to figure out which one I need?
Old Jul 10, 2008 | 07:40 PM
FunkyFord's Avatar
FunkyFord
jasongt06 and firepop5, I greatly appreciate your posts. Unfortunately, I could not find the resistor module after purchasing the replacement part. I saw a wire connector to a small box attached to the blower unit under the hood. I did a search on the part # (XL2H-19E624-AB) and found these 2 threads;
a/c controls are jacked up....HELP - Ford Explorer Ranger Enthusiasts Serious Explorations
99 Mountaineer with AC blower fan isues - Ford Explorer Ranger Enthusiasts Serious Explorations
Both state that the blower has a control unit and not a resistor module if the Explorer has automatic climate control. Oh well!
Again, thanks for your help.
Old Jul 10, 2008 | 08:36 PM
steve(ill)'s Avatar
steve(ill)
click on the 99 Mountaineer and read the info... thats interesting, i nver knew that. thought all had the resistor as firepop said.
Voodoo ChildVood
Feb 2, 2011 08:36 AM
2002sport
Escape & Escape Hybrid
Oct 23, 2010 11:01 AM
sparkieg
Nov 28, 2008 10:35 AM
wrenched
Apr 28, 2001 07:55 AM
