Where is this located? I'm trying to save a hundred bucks and install my aftermarket alarm myself. I have to get to the VSM, which is located here, but I can't find it. Any help would be very useful.
It has remote start, but I'm not installing it. It has shock,microwave, siren, door locks, 2 way paging, valet mode. It's made by Performance Teknique. In the vehicle's repair manual it says the place i install the door locking system is located in Center Dash Panel #201.
my truck is a 2000X, So this is where i found it when i did my install.
as your sitting in the drivers seat,looking at the steering wheel, below the steering wheel you see a panel, which you can remove by removing 4 pressure screws. Now still looking at the steering wheel, to the right of the steering colum (about 2'' to the right) you should see a gray connector with pink/yellow(-)
pink/light green(-)
this one connector has everything you need to lock/unlock,park lights etc..
here is a link to where you can also find wiring diagrams: 2000 Ford Excursion Alarm, Remote Starter, Keyless Entry Wiring Information
hope this helps, if you need anymore help let me know
as your looking at the steering wheel, right below it is a panel with 4 spring release screws, also to the right of the steering colum you'll see a gray connector ,it's about 2" to the right of the column, that gray connector have the door locks,the park lights etc...
