Vin Decode
Old Jul 5, 2008 | 06:46 PM
jlk5269's Avatar
jlk5269
Vin Decode
I need so help decoding the VIN on my F-250. F15ACAJ4191 is the VIN. Any Info would be appreciated. Thanks!
Old Jul 5, 2008 | 07:51 PM
mudslingin'78's Avatar
mudslingin'78
I am having trouble with this one. What year model is it? There should be six number on the end, cou the could the last A and J be numbers?
Old Jul 5, 2008 | 07:58 PM
76f350spercamprspeal's Avatar
Your VIN number: F15ACAJ4191
Your Model Year is 1978.
Truck Series: F150 2 Wheel Drive
Engine: Unknown, Please double check VIN number
Assembly on: Ontario, Canada
Old Jul 5, 2008 | 08:03 PM
mudslingin'78
Yea thats about all I could get as well.
Old Jul 5, 2008 | 08:04 PM
I think hes missing some letter\Numbers.
Old Jul 5, 2008 | 08:07 PM
mudslingin'78
Yea me too
Old Jul 5, 2008 | 09:48 PM
jlk5269's Avatar
jlk5269
I will double check the Numbers and post them Thanks
Old Jul 6, 2008 | 07:19 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are no numbers or letters missing, because...
1953 thru 1980 Ford truck VIN's are 11 digits. 1981 and newer VIN's are 17 digits.
If it's an F250 2WD Regular Cab, the VIN begins with F25, not F15.
A = 460 4V
C = Ontario Canada Assembly Plant
AJ4191 = 1978
Did you get the above VIN from the registration or off the Warranty Plate, located on the left door below the latch?
Ppl swapped doors due to accidents, and forgot to change the Warranty Plate, so the VIN on the door won't match the VIN on the registration.
Old Jul 6, 2008 | 02:50 PM
jlk5269's Avatar
jlk5269
The VIN is from the Cabs sticker on the Door Jam. I was given a 1973 Title with the truck but it had a different VIN. I am begining to think it had a cab from a 78 F150 put on if this is possible, and noone changed the sticker.
Old Jul 6, 2008 | 02:57 PM
NumberDummy
I doubt someone went thru the trouble of swapping cabs.
IMO: Someone changed the left door, why the VIN on the registration doesn't match. The doors are the same 1973/79.
There are two ID plates, the metal Warranty Plate which is riveted to the door and the white Certifcation Label (sticker) which was glued on.
One cannot remove the sticker without tearing it into pieces.
The VIN is listed on both.
The VIN is stamped on the right frame rail, just in front of the cab. It's lightly stamped, so will be hard to read, especially now since road grime and rust are coating the frame.
Obviously something is wrong, as the VIN you posted is for an F150 (5 lug wheels), the truck is an F250 (8 lug wheels).
What engine is it? 302 = 6 valve cover bolts / 351M/400 = 8 valve cover bolts / 360/390 = 5 valve cver bolts / 460 = 7 valve cover bolts.
The 360/390 were used 1973/76, the 351M/400 were used 1977/79.
Old Jul 6, 2008 | 04:21 PM
bucks77ford's Avatar
bucks77ford
Sounds like the cab was swapped if the sticker is what you are getting the VIN from. Is there not a VIN on the door tag or is that the same too.
The chassis VIN would confirm the title's VIN.
Trucks can have some really odd VIN info hence the term FrankenTrucks. Chassis', cabs, and doors get swapped all the time and what a truck once was is now a "built truck". Technically, these trucks should get inspected and have a replacement VIN tag from the DMV, but that is such a hassle, that most people just get a title to what they have whether it's the chassis VIN title or the body VIN title.
Old Jul 6, 2008 | 07:54 PM
jlk5269's Avatar
jlk5269
It is the door Jam sticker VIN that I posted. It Had a 400 built for street/ truck pulling. I am anxious to check the frame # when I get to my repair shop tommarrow.
Old Jul 6, 2008 | 08:27 PM
bucks77ford
Is your truck a 4x4???
Old Jul 6, 2008 | 08:31 PM
ford4604bbl's Avatar
ford4604bbl
My 75 Highboy was completely repainted and the door tag removed, well the paint guy lost the tag. I moved from one state to the next and the Gal at the DMV office goes out to look at the truck to match the VIN# from my previous title, I told her the door tag was missing but she was more than welcome to climb under the truck and check the number on the frame(right now I am laughing so hard deep down inside because she is all dressed up in fancy clothes) she looks at me with this dumb founded look and says "nah thats alright I'll believe you" and back in the office we go. It was one of the funniest things I ever saw gave me the title. One of these days I will get the replacement tag for it.
Old Jul 6, 2008 | 09:07 PM
jlk5269's Avatar
jlk5269
It is a 4X4 with Dana 60 rear and dana 44 front with 3 drive shafts
