Split ratio rockers?
Old Jul 5, 2008 | 02:45 PM
doug1222556's Avatar
doug1222556
I need some opinions on rocker ratios. I'm gathering parts for a 393 (399) stroker. 3.85 crank,.060 hyper pistons,Edelbrock rpm manifold and 750 carb, stock cast iron smog heads, self ported and polished with 1.94/1.60 valves. I'll have about 10:1 CR and plan on running a Speed-Pro CS1231R flat tappet hydraulic cam : adv.dur 290 int/300 ex.- 214/224 @ .050 with 112 lobe seperation. Basically a hot streeter. I am shopping for roller lifters and have a choice between 1.7, 1.6, and a 1.6/1.7 set. I am thinking 1.6 is what I want, but right now I can pick up a set of 1.6/1.7 for a pretty good price. There is not a big price diff. in any of them, though. Whatcha think?
Old Jul 5, 2008 | 05:59 PM
f_ford_custom's Avatar
f_ford_custom
1.6 is stock, 1.7 will net more lift with the same duration (under the curve) but will also run closer to coil bind.
for THAT cam, in THAT engine, I would go 1.7/1.7, that should keep you neer 1800-4250 rpm powerband.
on the other hand, you'll probably run out of head well before cam, so 1.7I/1.6E would also work.
a stock 400 has larger ports and valves 2.06/1.66 and runs around 282/292; 204/214; .484/.510 to net 1800-4000 rpm powerband
If possible, get a second opinion from someone with dyno software, they could tell you the difference better heads would make.
1bad67sbf
Mar 11, 2010 04:39 PM
cjm0269
Sep 20, 2008 11:09 PM
quadzjr
48
Dec 19, 2005 01:20 PM
MustangGT221
Dec 2, 2004 02:57 PM
fozzy
Sep 8, 2001 10:47 PM
