6.0 Vacuum Leak: Details Provided, Help!
Howdy all!
I have done a number of searches for my 2003 SD 4x4 PSD and still need help. My ESOF quit working about 2 years ago and I just used the manual hubs and figured I would fix the problem later (Later became now as I am currently unemployed!). About 1 month ago, the AC system started blowing out the vents (on my way to a hot NM antelope hunt!). I know this is a sign of a vacuum leak. I found two leaks under the truck where sagebrush broke the vacuum line between the wheels and pulled 1 line out of the right side and fixed them. Still no AC!
I bought a vacuum tester and found the following:
1: 16-17 in Hg to Canister
2: 16-17 in Hg other side of Canister
3: Vacuum pump never turns off!
4: Tested all vacuum lines to solenoid and they do not leak.
5: put vacuum line to solenoid then turned on 4 whd- Built to 7 in Hg then lost all pressure.
6: put vacuum line to 4 wd system and eliminated solenoid- found 16-17 in Hg at right and left wheels: I was pretty happy that the my line fix worked!
Questions:
1- The vacuum pump pulls 16-17 in Hg but never turns off. What pressure should I have and how long should it take to turn off?
2- Solenoid seems to work but only builds to 7 in Hg before it bled pressure... Ideas?
For now I have blanked off the vacuum line to the 4 wheel drive system and got the AC back but am worried the vacuum pump will go bad soon as it runs full time!
Thanks for your help,
Cory
Questions:
Cory
awq134
2009 - 2014 F150
32
03-19-2024 10:34 AM
xjcamaro89
2004 - 2008 F150
447
01-31-2022 07:35 AM
