have a 2000 f 150 4x4 oil is leaking from the seal on the passenger side differential on the front end. i went to ford to get a seal and see how much of a pita it would be to change they said the seal that i thought was leaking wasn;t the one it was acctually one inside the differential. just wondering if this sounded right to anyone else. The seal i thought that was leaking is right behind where the cv shaft bolts to the front diff. thanks for some help
Any help on this issue? I'm having the same problem, but I'm leaking oil out of all possible points (driver side differential output, passenger side differential output, and the input to the differential) All points started leaking at the same time.
hey man, i don't have that truck anymore but if i remember right it all of a sudden quit leaking, i'd check for a clogged vent sounds to me like. hope this helps a little
