E-Brake Pedal Question
Old Jul 1, 2008 | 09:24 AM
Steve_Uzi's Avatar
Steve_Uzi
Question E-Brake Pedal Question
Hello All,
I use my e-brake daily as my townhouse driveway has a slight incline. Sometimes when I release the pedal it doesn't come all the way up and the light remains on. Then when I go to release it again it comes up the remaining distance. Even if I hold the handle out during initial release it will sometimes leave the light on.
Questions:
  1. Is this something that can be adjusted?
  2. Have others experienced this problem?
Old Jul 1, 2008 | 09:36 AM
98greensi's Avatar
98greensi
How does the pedal feel? if it's soft and goes almost to the floor before it grabs you might just have to adjust the park brake as far as i know there is no self adjuster so you have to crawl under there and do it manually
Old Jul 1, 2008 | 09:37 AM
FatalErrorz's Avatar
FatalErrorz
You can either try to lube the mechanism, replace the cables, or....Jam that sucker tight when you set it, and just pop the handle to release it. It'll fly back all the way. Mine was doing the same thing. When I use it, I just max it out. It keeps it from sticking that way, also.
Book answer is to adjust, or replace the cables...I wouldn't worry about that personally until I had to.
Old Jul 1, 2008 | 09:48 AM
FatalErrorz
You adjust the tension at the cables. There isn't a way to adjust it at the rotor unless you pull the rotor off completely. If you do that, then you may as well replace the pads. Since it's a PARKING BRAKE, the pads should last many trouble-free years if they are released before driving. ALL adjustments after the pads are on, are made at the cables.
Old Jul 1, 2008 | 10:07 AM
98greensi's Avatar
98greensi
So is there an adjuster inside the drum? like normal drum brakes and i'm guessing there's no adjusting hole in the backer plate?
i've only had my truck 5 weeks and worked out of town for 4 of them I'm a heavy duty mechanic (mining) if your wondering, fatal
Old Jul 1, 2008 | 10:14 AM
FatalErrorz
I'm not wondering. There is an adjuster, but that's for setting the pads so they don't rub on the inside of the drum/rotor combo when you replace the pads. Minor adjustments are done with the cables. It's not an emergency brake, and it's not involved with the rear braking system (disc) so it's not an exacting science when adjusting them. You just make sure the vehicle holds in place, and release all the way.
Old Jul 1, 2008 | 10:58 AM
Steve_Uzi's Avatar
Steve_Uzi
My Truck holds - no doubt.... I will probably start by greasing the Mechanism... and then see about adjusting it...
Old Jun 16, 2010 | 06:53 AM
Steve_Uzi's Avatar
Steve_Uzi
So I did lube the cable and on occasion the ligth stays on - but I am dealing with it..
Fatal,
Ok - so now it doesn't hold (years later ) I looked under the truck last night and didn't see any Adjustments on the Parking brake cable what-so-ever!
Any help?
droidtn
Mar 6, 2014 09:01 AM
lamenytro
Jul 19, 2013 03:01 PM
ztodd377
May 28, 2010 03:10 AM
MustangGT221
Nov 18, 2005 04:30 PM
aikigod
Mar 11, 2003 07:15 PM
