low oil pressure
Old Jul 2, 2008 | 06:47 PM
Sark's Avatar
Sark
Thumbs up
Originally Posted by bismic
You really want to avoid will-fit filters:
<TABLE style="WIDTH: 607pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=809 border=0 x:str><COLGROUP><COL style="WIDTH: 607pt; mso-width-source: userset; mso-width-alt: 29586" width=809><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 607pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: transparent" width=809 height=17>http://www.forddoctorsdts.com/articles/article-06-04.php</TD></TR></TBODY></TABLE>
<TABLE style="WIDTH: 607pt; BORDER-COLLAPSE: collapse" cellSpacing=0 cellPadding=0 width=809 border=0 x:str><COLGROUP><COL style="WIDTH: 607pt; mso-width-source: userset; mso-width-alt: 29586" width=809><TBODY><TR style="HEIGHT: 12.75pt" height=17><TD class=xl24 style="BORDER-RIGHT: #d4d0c8; BORDER-TOP: #d4d0c8; BORDER-LEFT: #d4d0c8; WIDTH: 607pt; BORDER-BOTTOM: #d4d0c8; HEIGHT: 12.75pt; BACKGROUND-COLOR: yellow" width=809 height=17>http://www.youtube.com/watch?v=Lm3mOhQRqr4
Excellent YouTube video! If this doesn't make THEM a believer then we're wasting our time!
Thanks!!!
Old Jul 3, 2008 | 03:58 PM
dduf's Avatar
dduf
check ball
industrial dude
Did you have any power loss and can you remove pump by just removing turbo or does intake have to come off too? This thing is making me crazy, my dealer says he has never heard of check ball ciming out. If I don't figure it out soon I will have to bring it to dealer, but then I will be paying 80-100 an hour for them to recheck everything I have checked or replaced.
Thanks
Dale
Old Jul 3, 2008 | 04:01 PM
dduf's Avatar
dduf
Industrial dude
did you fing the ball or will it do damage to engine rattling around somewhere.
Dale
Old Jul 3, 2008 | 08:06 PM
Industrial_dude's Avatar
Industrial_dude
my mechanic is working on it not me. I couldnt tell you exactly I just know he had to completely remove the intake turbo an I think its under the intake manifold?? dang I was there earlier I was going to take pictures for you and I totally got side tracked I wanted to take a pic of the plug he made on it. As far as the ball bearing I think it just ends up in the oil pan and doesnt cause any harm if it were to cause any harm it wouldve done it on its way down when it spit it out(just assuming) the truck never lost power just made a weird whindy noise like a power steering pump low on fluid. Just go to the 6.0 bible figure out where the HPOP is once you get your hands on it, Tap the hole make sure you dont get metal shavings in there tho, plug it up and you should be good. Im going on monday again and I doubt he will have it put together since its a long weekend so ill try not to forget to take pics.
Old Jul 4, 2008 | 06:57 AM
dduf's Avatar
dduf
oil pump
thanks for the info industrialal dude, I was ready to throw in the towel but maybe I will give it one more shot. I may have a guy with some diesel experience who can help me also, although it is mostly cat, cummins, and detroit. to be losing pressure in this way the guy who put engine together for me says, this should be a substansial leak. the only other place looking at engine system that could bleed of pressure from lower pump are seals and o-rings under filter plate, and it would seem some oil would spray out if this were the case. well, guess I'll enjoy the holiday and resume beating my head against the wall tomorrow. lol. if you do get any pics of the pump and where check ball should go as well as fix for it could you email them to me,
ddufr@verizon.net thanks, Dale
thegreatwhitefarmer
18
Mar 3, 2009 04:40 PM
topfisherman
15
Oct 12, 2007 09:46 PM
Slade901
17
Dec 24, 2003 11:33 PM
truckman79
Aug 29, 2003 08:06 PM
rodehog
Apr 6, 2003 10:09 AM
