5.0 Oil Galley Plugs
I just installed a rebuilt motor into my truck and I am having low oil pressure problems. The machine shop put together the short block and then I installed the heads, lifters, valve train, oil pump, and intake. I can get 20 psi when I'm priming it, but when I start it up it idles at 5psi and then drops off to zero. I checked the front oil galley plugs by the timing chain and they were still in. I called the engine builder and he said to check the oil galley plugs in by the lifter valley under the lower intake. I have not opened it yet, but I was looking at some pictures I took and I don't see where any plugs would be. All I see is two threaded holes for the spider and 4 holes for the oil to drain back. So are there any oil galley plugs in the lifter valley? If so where are they?
Well what I might do is change the filter and prime the engine again with the timing cover off so I can see what is going on around the pump and to make sure nothing is leaking past the oil galley plugs. I talked to the machine shop yesterday and they, at the moment, can't think of why it would have no oil pressure like this will all the oil galley plugs in.
There is one under the intake at the rear of the block right at rear cork gasket area.
It is the main oil galley.
Here is a picture
http://www.mustang50magazine.com/tec.../photo_02.html
Here is a picture
Here is a picture
Here is a picture
Ok, hopefully I can get that plugged up this weekend and get the truck running. Of hand, does anyone know the diameter of that plug? I had the machine shop send me one, but I want to double check the size in case I need to order a different one in. Any tips for installing the plug? I've never put one in and want to make sure it is right.
I use a socket that just fits inside the plug, I also use that brown, thick, nasty stuff on the outer edges of the plug, I think it's called permatex gasket maker.....it's real think stuff in a tube....Not sure on the name. I'll check tomorrow when I get to the shop. Works good...
it surprises me you got that much pressure with that plug missing.......
Originally Posted by BEWOLD
A friend had a shop do his 454 chev and had low pressure as well, he found a couple of his screw in galley plugs to have small holes in the middle(were meant for something else) and the shop installed them by accident.
