distrubutor won't fully seat
Old Jun 27, 2008 | 04:52 PM
JP808's Avatar
JP808
needs 1/2 to 3/4 inch to go but wont drop any further, tried 2 dizzys , both have been in before any thoughts, thanks, jim
Old Jun 27, 2008 | 05:17 PM
unrulee's Avatar
unrulee
Sounds like you're hitting the oil pump drive. Have someone bump the key while you give the dizzy a little downward pressure, it should go.
Old Jun 27, 2008 | 06:59 PM
greenego's Avatar
greenego
If the engine hasn't been bumped since you removed the distributor then you are a tooth or two off when you are trying to reinstall it. Lift it out just enough to move it another tooth and try it again until the slot on the end of it lines back up with the oil pump drive.
Old Jun 27, 2008 | 07:26 PM
JP808's Avatar
JP808
thanks for the input,have tried above methods and others with no luck!the pump shaft will not stay centered so there for its possible the shaft broke loose of the pump . I will remove pan tomorrow and go from there and let you know. this all started because msd ready to run dizzy went bad . its either the modual or pickup. the msd tech guy said that all rtr dizzy are not meant to be rebuilt by the public(bad design he said). $111 plus shipping both ways for them to fix! at 1 1/2years old and the certanty that it will break again its back to stock for know!
Old Jun 28, 2008 | 05:09 PM
slowsuki's Avatar
slowsuki
same thing just happened to me a couple days ago. pump shaft came out of pump. i used a 1/4 socket and extention to put it back in. the first time it took 10 min after that it was about 1 min to get it. i put in a procomp hei, 60 bucks off ebay runs great.the clip comes off the rod and after that when you remove the dizzy it pops out.
Old Jun 29, 2008 | 05:00 PM
danlee's Avatar
danlee
I usually turn the motor by hand, while someone keeps pressure on the distributor until the dist. drops onto the pump shaft.
The pump shaft will sit a little crooked when the dist is out, it doesn't mean that it's broken.
Just keep trying to seat the dist. It's still engaged with the cam, so your timing is not affected.
mskeen
1983 - 2012 Ranger & B-Series
Jul 10, 2014 10:43 AM
beastlyf250
Jan 31, 2008 05:48 PM
Hitches1
Dec 19, 2007 10:11 PM
mgm5555
May 24, 2003 02:55 AM
Franklin2
Dec 30, 2001 09:14 PM
