Viton Return lines?
Old Oct 15, 2010 | 11:22 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
Mine have seen -21F without issues!
I used the 5119K841 on my 86 ...
I didn't touch them so I don't know at what point they become brittle, I suspect -15F is where they stiffen and become inflexible.
Considering they have no movement I suspect they'll be fine much colder, but I have no facts to back that assumption up with.
They also have two different durometer hardnesses. 60A=Soft and 75A=Hard.
The numbers I gave above were for the Hard (75A).
I might try the Soft next time.
I just installed a Pensacola kit with Viton o-rings on the 7.3 thats going in my 86 so I am not going to use Viton hose on it at this point in time ... I don't care about this motor, it's temp till I fix my 6.9 RIGHT! (Shhh, Don't tell my ol'lady but I might just blow it up so I'm forced into fixing my 6.9 sooner ... )
If you look at McMaster-Carr Viton® Fluoroelastomer they state:
<table><tr><td>Rubber</td><td>Viton® Fluoroelastomer</td></tr><tr><td>Material</td><td>Viton® Fluoroelastomer</td></tr><tr><td>Shape</td><td>Single Line</td></tr><tr><td>Reinforcement</td><td>Unreinforced</td></tr><tr><td>Maximum Pressure Range, psi</td><td>Not Rated</td></tr><tr><td>Low Temperature Range</td><td>-99° to -1° F</td></tr><tr><td>High Temperature Range</td><td>+301° to +500° F</td></tr><tr><td>Operating Temperature Range</td><td>-15° to +400° F</td></tr><tr><td>Bend Radius</td><td>Not Rated</td></tr><tr><td>For Use With</td><td>Ethylene Glycol and Water</td></tr><tr><td>Fittings Used</td><td>Barbed</td></tr></table>
-Enjoy
fh : )_~
mlouritt
Jan 29, 2011 01:38 PM
whiteaddiction
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Nov 17, 2010 08:37 PM
barca_texas
Oct 4, 2010 09:54 AM
galute
Nov 22, 2009 09:23 PM
Dodge/Cummins
Oct 20, 2008 11:58 PM
