Sponsored by: Real Truck
ATF Change
Old Jun 26, 2008 | 12:45 PM
calf roper's Avatar
calf roper
ATF Change
I was looking in Mods and Maintenance on chainging the Transmission fluid and was wondering if anything has changed or been updated.I have replaced the strainer 3 times but have never done a complete drain of the system.Ford said that they no longer made Mercon and just made Mercon V for everything and it would be ok to use.Thanks
Old Jun 26, 2008 | 02:06 PM
redford's Avatar
redford
FTE Leadership Emeritus
Yes, Mercon V is now the fluid that should be used for the 4R100.
Old Jul 1, 2008 | 02:32 AM
Izb's Avatar
Izb
Some questions about ATF change (Mercon->Mercon V):
1. Which methods are correct for fluid change (after removing the transmission drain plug and draining the transmission fluid):
Method 1. Apply the break(pedalbreak or handbreak). Start the engine and run it at idle speed for five minutes while shifting through all shift lever positions.
Method 2. Start the engine and run through all gears for a total of five minutes at idle.
- Is idle enough to mix fluids? Or middle speed better?
- What is better: running with break or without break?
Method 3. Start the engine and run at MIDDLE speed through all gears for a total of five minutes.
- Can middle speed (instead of idle) damage the transmission?
2. Is 5 minutes enough to mix fully new fully ATF with old ATF?
3. How many times do you recommend repeat this steps?
Old Jul 1, 2008 | 05:53 AM
ken kenmnedy's Avatar
ken kenmnedy
take to service center and get the trans flushed best!!!!!
Old Jul 1, 2008 | 06:28 AM
F350-6's Avatar
F350-6
If you want to change the fluid, this is the easiest way to do it. Changing ATF Fluid in a E4OD and 4R100 transmission .: Articles
Old Jul 1, 2008 | 07:38 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
None of those steps are correct. I don't understand why you WANT to mix old and new fluids. That doesn't make any sense to me.
Follow the instructions the F350-6 posted. That's the way to do it. One caveat, though. The instructions are a bit out of date. MERCON V has replaced MERCON.
Old Jul 1, 2008 | 07:51 AM
kenneBF250V10's Avatar
kenneBF250V10
Check this link out. Click on the icon that looks like a gear shifter.
BG Automotive Maintenance Services
Then click on this link to locate a shop near you.
BG Findashop - Search for an authorized BG service center near you!
I just had my tranny and power steering done. The tranny flush was only $125.50. To me, for that price it isn't worth fooling around with it myself. That price included the new fluid.
kawika
49
Jun 23, 2021 11:47 PM
Firefighter 1406
Oct 20, 2016 02:50 PM
derek0525
Aug 12, 2016 10:45 AM
Bullitt390
Feb 24, 2015 01:26 AM
chrison600
Apr 29, 2003 01:09 AM
