What is the final verdict on mercon/dexron or mercon v
Old 08-11-2016, 07:59 PM
derek0525's Avatar
derek0525
derek0525 is offline
I'm going to be flushing the system is it still ok to use mercon/ dexron or do I have to use the mercon v? I would rather go with the cheaper option.
Old 08-11-2016, 08:14 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Received 1,570 Likes on 1,049 Posts
You get what you pay for. MERCON V is superior to DEX/MERC, which may or may not meet the now discontinued MERCON rating. It's your transmission, you don't HAVE to use either.
Old 08-11-2016, 08:18 PM
derek0525's Avatar
derek0525
I will use mercon V if that's what it needs but if mercon/dexron was still acceptable I would use it. What about the transfer case?
Old 08-11-2016, 08:24 PM
FiznUKa's Avatar
FiznUKa
FiznUKa is offline
I use Valvoline transfer case fluid. The are stories about transfer case case's being broken from the use of Mercon V but I don't believe them. Ford also has a transfer case oil that they call for now. Opinions will vary.
Old 08-11-2016, 08:55 PM
Colorado Horseman's Avatar
Colorado Horseman
Colorado Horseman is offline
I have a 2002 manual and shift on the fly.
Dexron 3 is fine by me in tranny and transfer case as that is the spec called for. YMMV but I doubt it.
Old 08-12-2016, 04:30 AM
derek0525's Avatar
derek0525
Mark would the super tech Walmart brand mercon v be ok to use? I'm guessing as long as it's mercon v it meets the ford specs?
Old 08-12-2016, 08:35 AM
Firefighter 1406's Avatar
Firefighter 1406
Firefighter 1406 is offline
I used the Supertech Mercon V this last trasmission / transfer case flush. I personally haven't had any issues. I just couldn't spring for whatever was at Autozone at twice the price.
Old 08-12-2016, 10:45 AM
Mark Kovalsky
The problem is that nobody produces DEXRON III or MERCON any longer. There are many fluids that say they are for use in transmissions that used DEX or MERC, but what spec are those fluids produced to? Nobody knows. Ford stopped licensing MERCON, and GM stopped licensing DEXRON III. Both are obsolete specs. MERCON V has replaced MERCON. Ford licenses MERCON V and monitors the fluids to ensure they meet the spec.
Yes, it's fine. In order to say MERCON V on the label it has to be certified by Ford to meet the MERCON V spec.
hamster
1999 to 2016 Super Duty
38
04-20-2016 06:20 AM
pony
03-27-2014 10:07 PM
RTF
1997 - 2003 F150
01-11-2011 01:22 PM
mich800
1997 - 2003 F150
03-17-2008 09:13 PM
d0n_3d
1997 - 2003 F150
12-09-2005 04:15 PM
Quick Reply: What is the final verdict on mercon/dexron or mercon v
