?'s about these Dart Heads
Old Jun 25, 2008 | 04:18 PM
bigbad'945.0's Avatar
bigbad'945.0
I've been considering buying these heads for my truck. I don't know much if anything about cylinder heads, so would these be a good set to go with? they have another set with a higher intake port and chamber volume, but would it be overkill? This is for my daily driver. And when they say, "Assembled", does that mean i can literally take off the old set and put the new ones on?
Dart: Ford PRO1 Heads
SBF PRO1 170 Assembled
<TABLE cellSpacing=0 cellPadding=1><TBODY><TR><TD class=blue style="PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px">Item</TD><TD style="PADDING-RIGHT: 0px">SBF PRO1 170 Assembled</TD></TR><TR><TD class=blue style="PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px">Material</TD><TD style="PADDING-RIGHT: 0px">Aluminum</TD></TR><TR><TD class=blue style="PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px">Intake Port</TD><TD style="PADDING-RIGHT: 0px">170cc</TD></TR><TR><TD class=blue style="PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px">Chamber Volume</TD><TD style="PADDING-RIGHT: 0px">62cc</TD></TR><TR><TD class=blue style="PADDING-RIGHT: 0px; PADDING-LEFT: 0px; PADDING-BOTTOM: 0px; PADDING-TOP: 0px">Intake/Exhaust Valves</TD><TD style="PADDING-RIGHT: 0px">1.94/1.60</TD></TR></TBODY></TABLE>
<TABLE class=subcart cellSpacing=0 cellPadding=0><TBODY><TR><TD style="PADDING-TOP: 6px" width=1>PRICE:</TD><TD style="PADDING-TOP: 6px">$745.54
(each)
Old Jun 25, 2008 | 04:28 PM
auot02's Avatar
auot02
that's to pricey for a 170cc head.i'd look at the edelbrock performers or trickflow tw.is your truck a 302 or 351?i use to run afr 165's on the 302 in my 94 f150 but will be using edelbrock victor jr's on the 351w i'm currently building.also you will have to determine correct pushrod length with a checker and those probably require stud mounted rockers!
Old Jun 25, 2008 | 05:58 PM
Conanski's Avatar
Conanski
All the Dart heads use stud mount rockers so you'll need rockers, hardened pushrods and guide plates to put these on a 5.0. They also do not have provisions for EGR or air injection, so they are not emissions compliant. Not only that, but you'll probably need bigger injectors as well and that opens a whole other expensive can of worms on an EFI motor. The Pro1 heads are comparable with the AFR heads in terms of air flow, which is a big step above the Edelbrock Performers, these will turn a 5.0 into a real screamer.. as long as you have all the other parts to support them.
Old Jun 26, 2008 | 03:16 PM
bigbad'945.0
These sound like more trouble than their worth. What exactly has to be done to put these puppies on my rig? These AFR 165's have caught my interest as well. Or are they non emmissions compliant as well? Both have the performance gains i'm looking for, but i'm looking for relative ease when it comes to installing them. Are there any good cylinder heads similar to these that are made for an EFI 302?
Old Jun 26, 2008 | 04:44 PM
auot02's Avatar
auot02
the afr 165's are smog legal and can be bought with a pedastal rocker setup like stock.for the money and gains it's hard to beat the edelbrocks.also you'll be fine with 19lb injectors,my truck ran1/8 mile with stock injectors and never had one issue!i even have a vid of it on streetfire.net.give more details about your truck and maybe we can lend more specific advise!
Old Jun 27, 2008 | 09:08 AM
Conanski's Avatar
Conanski
For bolt-on convienence either the Edelbrock and AFR emissions legal heads would be the way to go. You can probably get away with the stock 19lb injectors, though using an adjustable FPR to bump fuel pressure will help reduce the amount the injectors spend at 100% duty cycle.
Old Jul 6, 2008 | 06:56 PM
bigbad'945.0
Thanks Conanski
Old Jul 9, 2008 | 10:09 PM
bigbad'945.0
my truck's a 94 single cab 5.0 transmission's a three speed...not sure of the exact name of it. mods so far a just a k&n drop in and dumped ravin exhaust
hindmarsh
Sep 23, 2012 10:01 PM
dave boley
28
Feb 12, 2009 12:58 PM
MBBFord
2004 - 2008 F150
16
Nov 7, 2007 12:24 PM
justranchin
Feb 17, 2007 08:35 AM
