Sponsored by: Real Truck
Any electrical guru's here...
Old Jun 28, 2008 | 09:33 PM
ReAX's Avatar
ReAX
The correct drain is 20-50mA. You may have to shunt a little current with a test wire to begin the drain if the meter doesn't have the right resistance.
Now, one battery could be pulling the other down. I don't believe ford uses any isolation between them. If one has a high resistance, it will suck power from the other, then once it's full and the other is weak, it will try to charge that one. Bouncing back and forth will lose a lot of power.
My single battery truck is only good for about 4 days if I didn't drive a lot before parking it, and I am running an optima blue top deep cycle.
The difference in the power from the alt to battery and alt to rad is going to be a ground. In school last week, they recommended upgrading the grounds (batt to frame and frame to block) to the largest wire in the vehicle. Also upgrading the alt wire to atleast 8ga. My stock Alt wire was pretty close to an 8, but if you can get a couple of feet of 4awg you'd be further ahead. Run all of these wires and the stock, they also recommended fusing the new Alt power wire.
Old Jun 28, 2008 | 10:52 PM
aldridgec's Avatar
aldridgec
Originally Posted by John Irwin
I was thinking the same thing - if they were dead for that long, they can't be any good. I changed them yesterday, and if everything works out, I'll let this thread die. If it doesn't, I'll go back to testing.
Actually, report back so we know what fixed it!
Old Jun 30, 2008 | 01:41 PM
John Irwin's Avatar
John Irwin
Excellent info elmo8641! I didn't know you could reawaken the computers so I probably did. My kid has the truck up in the mountains right now, so I'll work on it after she gets back if it's still having problems. Sorry to take so long responding - I'm having a hell of a time loading this website. It's a good 5 minutes to get to this thread. I don't know why, I have hi speed internet, and all my other sites load normally.
Old Jun 30, 2008 | 02:30 PM
99f350sd's Avatar
99f350sd
Get a good clamp on dc amp meter and forget taking the cables off and on. 20-50ma is correct for computer draw clock etc..
Old Jun 30, 2008 | 02:50 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, a good ole Amprobe goes a long way
Old Jul 3, 2008 | 12:02 AM
John Irwin's Avatar
John Irwin
Progress report...
The truck is back from the mountains, and I'm going to leave it sit for a week and see if it still starts, but I'm sure it will. The reason I'm so sure is because I put one of the old batteries on an electric fencer yesterday, and it never made the night. A good battery will usually last over a month on a fencer, so the batteries were the culprit. Thanks to all who answered me, and imparting your wisdom on here. I learned a lot in the last few days - I've been doing my own wrenching for the last 35 years, and I never knew about the test light/pulling fuses trick. I hope this thread can help somebody else. That's why I used the word "electrical" in the topic title to help a search engine find it. I'm smarter than I look...
Old Jul 3, 2008 | 08:55 AM
krewat's Avatar
krewat
Thanks for reporting back John - just make sure you let us know if the truck starts
One thing that can really tell you a lot about a battery is a load-tester - it's just a big heater element with a meter on it - hit the switch and watch the needle - if it drops too far too fast, the batt is done for.
Mine looks like this, different brand, but same idea:
Actron®
It's helped me quite a bit since I bought it 10 years ago
mrlexse
Sep 9, 2016 05:42 PM
FOCUS
May 9, 2016 08:00 AM
Farmboy1539
Jul 31, 2015 01:13 PM
bigrigfixer
All Things Towing
26
May 8, 2015 10:09 PM
