Oil pump shaft help!
Old Jun 25, 2008 | 09:00 AM
ksubigbuck's Avatar
ksubigbuck
Anybody have any tricks for getting the shaft up into the dizzy hole? I can't seem to even find the hole because I can't see it. Would it be easier to just remove the distributor and drop it in from there?
Thanks,
Hunter
Old Jun 25, 2008 | 09:01 AM
ksubigbuck's Avatar
ksubigbuck
Sorry, motor is a 351w.
Thanks,
Hunter
Old Jun 25, 2008 | 09:05 AM
Conanski's Avatar
Conanski
What are you doing? Sounds like you have to oilpan and pump off. It would help you see it is the distributor was out, but you want to put the shaft in from the bottom and make sure the little metal ring is around it, this prevents the shaft from being pulled out of the pump when the distributor is removed.
Old Jun 25, 2008 | 12:13 PM
ksubigbuck's Avatar
ksubigbuck
Thanks Conanski! I ended up finding the hole by blindly poking and prodding with the new shaft. I'm going to pull the distributor to prime the pump anyway, so I'll make sure everything looks good when I do that. And yes, I was replacing some stuff: HV oil pump, pickup tube, pan gasket, rear main seal, main bearings, and rod bearings. And now I have a whole new problem...when I lowered the motor back onto the mounts it settled a little to one side, so it's tilted in the mounts. Got any suggestions for getting the motor centered in the mounts? In the mean-time I'll be searching old posts to see if anyone else has had this problem and what they did to fix it.
Thanks again,
Hunter
Old Jun 26, 2008 | 06:47 AM
alz's Avatar
alz
Yeah, I had that problem. You just got to lift it back up and move it into place.
Use a rubberband to hold the pump shaft in place while you install the pump. Just a trick I use that I saw on this forum.
DR Smith
Feb 15, 2014 10:09 PM
Donzi Dude
Nov 8, 2013 06:14 AM
ford390gashog
May 17, 2008 06:53 PM
arnold
2004 - 2008 F150
Nov 11, 2007 10:46 PM
slammed77
Jun 2, 2004 10:20 PM
