idle ac problem
Old Jun 25, 2008 | 12:19 AM
gbrewer's Avatar
gbrewer
idle ac problem
I have an 87 f150 4.9l, just bought less than 1 yr ago, the previous owner had disconnected the power from the ac compressor. I dont know why. Any idea why it was disconnected. What is a reason for disconnecting ac compressor? I plugged it back in, but no cold air. Refilled ac with freon, now it provides cool air. BUT it stalls easier when first started. It used to rev higher when started then slow down gradually. Now it starts out lower rpm and stalls easily. Runs fine after started 2nd or 3rd attempt. I've read some about IAC valve. Could this be the problem? If so how do you clean it out or does it have to be replaced.
big-papa
1997 - 2003 F150
Mar 29, 2011 09:09 PM
Reed
Nov 22, 2010 10:20 PM
1-bassman
Bronco II
Sep 9, 2010 05:36 PM
gbrewer
Jun 28, 2008 08:24 AM
Rock Hayag
Aug 9, 2004 04:10 PM
