idle ac problem
Old Jun 25, 2008 | 12:19 AM
gbrewer's Avatar
gbrewer
idle ac problem
I have an 87 f150 4.9l, just bought less than 1 yr ago, the previous owner had disconnected the power from the ac compressor. I dont know why. Any idea why it was disconnected. What is a reason for disconnecting ac compressor? I plugged it back in, but no cold air. Refilled ac with freon, now it provides cool air. BUT it stalls easier when first started. It used to rev higher when started then slow down gradually. Now it starts out lower rpm and stalls easily. Runs fine after started 2nd or 3rd attempt. I've read some about IAC valve. Could this be the problem? If so how do you clean it out or does it have to be replaced.
Old Jun 25, 2008 | 08:23 AM
Conanski's Avatar
Conanski
The IAC is on the side of the throttlebody, it's the long cylinder like thing. These can be cleaned somewhat by spraying some carb cleaner into the ports while the engine is running, but taking it off and soaking it overnight will do a better job.
Doe your AC clutch cycle? Meaning can you hear it engage and disengage every minute or so as the motor runs? If it stays engaged all the time the clutch may be bad or the pressure switch is bad/disconnected, it's on the coolant line over near the air box. The compressor puts quite a load on the motor and it should not be engaged when the motor starts, if it is this will make it stall in many cases.
Old Jun 27, 2008 | 09:59 PM
gbrewer's Avatar
gbrewer
thanks next day off i'll check it out
Old Jun 28, 2008 | 08:24 AM
Conanski's Avatar
Conanski
A clarification if I may, the AC pressure switch is on the line over near the HVAC blower.
big-papa
1997 - 2003 F150
Mar 29, 2011 09:09 PM
Reed
Nov 22, 2010 10:20 PM
1-bassman
Bronco II
Sep 9, 2010 05:36 PM
Rock Hayag
Aug 9, 2004 04:10 PM
