Stock Cat
Old Jun 23, 2008 | 09:54 PM
JROSCO6's Avatar
JROSCO6
Stock Cat
Whats the best way to howle it out? I have a friend who works at ford and gave it to me. Ive heard of ussing a pipe but do i have to get all the honeycomb out or just the center.
Old Jun 23, 2008 | 11:09 PM
fsholder's Avatar
fsholder
Did mine this weekend and it took about an hour with a piece of pipe and got it all out. Not much sound difference but hoping for lower EGT and another MPG or so.
Old Jun 24, 2008 | 02:00 AM
mxer0022's Avatar
mxer0022
you might get lower EGT's but i doubt you are going to get a noticeable MPG difference. i got the MBRP cat delete pipe and i didn't even see a difference in my MPG's. with the kitty gone the biggest thing i noticed was the whistle was louder. thats it, but i don't have a pyro gauge yet so i don't know about the EGT's. i'm sure they went down as well.
Old Jun 24, 2008 | 11:48 AM
cartmanea's Avatar
cartmanea
Did it affect your spool-up time at all?
Old Jun 24, 2008 | 12:03 PM
mxer0022's Avatar
mxer0022
nothing that was really noticeable. it is just a tad slower when you hammer down from a dead stop but the secret is to just roll on the throttle and the lag time decreases considerably!
Old Jun 24, 2008 | 06:35 PM
Super Steve's Avatar
Super Steve
I used a 3/4 inch bar, about 5' long, and a 3lb sledge. It took a litle work, but it is now hollow and all that stuff is gone.
Old Jun 24, 2008 | 09:18 PM
18vtx00's Avatar
18vtx00
a six pack and bar works well.. I just left my kitty on the shelf in the shop, better whistle and if you remove it on a stock truck it will smoke a bit on acceleration.. Hard to tell if I actually dropped and EGTs or not since you would need to record a few exact same trips..
Old Jun 24, 2008 | 09:36 PM
StealmyTruck's Avatar
StealmyTruck
Blast it super hard with a tire iron and use spell check!
Old Jun 24, 2008 | 09:53 PM
18vtx00's Avatar
18vtx00
spell check,,hey we all need it..we can read it anyways..
Old Jun 25, 2008 | 05:32 PM
Super Steve
Hows the kitty going to get gutted if you're at a bar with a six pack?
Old Jun 25, 2008 | 05:43 PM
18vtx00's Avatar
18vtx00
Smile
Are you serious??
get a six pack remove the cat,then gut it w/ a BAR.
Not go to a bar.
Old Jun 25, 2008 | 10:57 PM
Layed Out 100's Avatar
Layed Out 100
Thats where you go when you get finished
Old Jun 26, 2008 | 01:14 PM
OZX1's Avatar
OZX1
Most report -200 degrees on EGT's and better turbo whine but nothing more. If anything, higher exhaust pressure would decrease spool time. Removing or gutting the CAT decreases exhaust pressure... Applying that logic, and if it indeed had any effect, it would likely be undesirable.
Old Jun 26, 2008 | 02:08 PM
cartmanea's Avatar
cartmanea
It reduces pressure after the turbo, which increases the pressure drop through the turbo, which mean more energy transferred to the turbo. It probably would decrease spool time, but maybe not noticeably.
Old Jun 26, 2008 | 02:31 PM
w_huisman's Avatar
w_huisman
I'm with cartmanea... seems to me that decreasing the post-turbo exhaust pressures would increase the pressure differential across the turbo. It would still take the same upstream pressure to turn the turbine blades, so upstream pressures wouldn't be changed by gutting the turbo.
No first hand experience with this. That's just how I envision it.
