Does anyone have anything else to add to it or something else I should do while im in there? I plan on cleanig up the fuel bowl and im going to look at my lines and see if they need replacing.
Do I need a IPR from a SD or will mine work?
Got to love E-bay, Brand new still in the box SD HPOP for 310 but I have a coupon and it made it under 289 shipped.
Awesome deal. You should be fine with the instructions. tjbeggs has some torque specs in his pics I believe. That also helped me. Your IPR will work in the SD pump. You will just have to change out your connections from your stock pump.
Good luck. It is not hard just get an old comforter to throw on the radiator and a heavy cooler or chairs to stand on. I prefer the heavy cooler idea 'cause it must be full to be heavy. LOL
Now it makes sense, Neal was talking about the connections for the high pressure oil lines, not IPR connectors.
Here's a picture that shows both the SD and OBS pumps and the oil line fittings. The SD comes with quik connects and OBS uses AN fittings. As you can see I've already put the OBS fittings on the SD pump. When you remove the fittings you'll see the checkvalve.
Yes I did leave the springs and check valve thingy's out on mine.
And No it won't take long to start it should start even quicker and better. Mine did. Also do the HP oil crossover (HPX) to get it started quicker and smoother.
