Sponsored by: Innova
92 Explorer JBL Subwoofer removal / replacement
Old Aug 25, 2001 | 03:58 PM
charlez's Avatar
charlez
Old Sep 3, 2001 | 03:40 PM
ranjan's Avatar
ranjan
Anyone know how to remove the subwoofer in the passenger side rear cargo panel? Also is there is an aftermarket replacement?
Thanks
Old Apr 10, 2003 | 10:47 PM
SoulRebel's Avatar
SoulRebel
Let me know if you get any information on removing the sub.
I have a 92 EB Explorer, and just today, my sub cut-out. All the other speakers work fine.
Old May 5, 2003 | 02:37 PM
craigdallen's Avatar
craigdallen
Ditto on that...
My '95 Explorer sub is out. I need to find someplace to buy a replacement sub.
Old May 5, 2003 | 07:42 PM
PrPlayboy's Avatar
PrPlayboy
Here is JL's link with a install sheet at the bottom that should answer some questions. Stealth box
Old May 6, 2003 | 03:45 PM
SoulRebel's Avatar
SoulRebel
The JL StealthBox was one option I looked at. The steps in the link PrPlayboy provided (Thanks!) was how I basically removed my old sub and sub-amp.
The key is carefully removing the inside, passenger-side panel in the cargo area (and having the right tools to do so).
I actually opted to go a little cheaper route and just got an external sub and a new single channel amp for my sub, which I tucked away in the cargo area where the old sub & sub-amp were. I also got a new deck, as the factory one just didn't have enough power to push my new components. The CD player hadn't been working quite right either, so I knew I would be replacing it at some point in time.
I gave up some space by having the external sub, but at least I stepped up from the factory 5-51/2 to a 10". Sounds really good though!
Thanks again PrPlayboy for the response and the link.
Old May 6, 2003 | 03:50 PM
PrPlayboy's Avatar
PrPlayboy
No problem. Glad i could help.
Old May 6, 2003 | 04:39 PM
craigdallen
Is it not possible just to buy a replacement speaker and utilize the existing wiring and amp?
These other solutions require a significant investment in time and energy. I guess I'm just lazy...
Old May 6, 2003 | 06:00 PM
SoulRebel's Avatar
SoulRebel
Provided your amp is still OK, and it is just the sub that needs replacing, you may be able to get away with just replacing the sub. I'm not 100% certain what exact issues you may or may not have with this, but it may be more difficult than you would expect to simply replace the sub.
The wiring on the factory stuff isn't especially 'friendly' for adapting after-market equipment, at least that has been my experience.
Not sure if that helps or not, hopefully it does a little.
Good luck.
Old May 6, 2003 | 07:28 PM
PrPlayboy's Avatar
PrPlayboy
You can replace the sub, but first remove it and see what the specs are. Mine is a 8" DVC 1.3ohm 60watt per coil. The way i had to remove the sub was to remove the enclosure it was in and remove a screw that goes into the magnet, then remove the 8 or so screws in the front holding it in. If you do find something to replace it I would go with something as close to the specs as posible with a high sensitivity rating.
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Roachfood
Mar 11, 2002 10:21 PM
