regulator on MAP sensor
Old Jun 20, 2008 | 09:55 AM
jleal_21's Avatar
jleal_21
Someone told me to put a regulator on the map sensor vacuum hose and regulate it 6lbs so the sensor won't cut off the fuel pressure, and the turbo can build up more boast. Will this harm anything?
Old Jun 20, 2008 | 11:41 AM
Neal 97 250's Avatar
Neal 97 250
Some people do this when they make big boost #'s and set the regulator at 22psi. You only need to do this if you make more than 25psi boost.
Old Jun 20, 2008 | 01:13 PM
tjbeggs's Avatar
tjbeggs
Yep Neal is right on. You will want it set much higher than 6 psi. I am set right around 22 right now.
Old Jun 20, 2008 | 01:57 PM
jleal_21's Avatar
jleal_21
will that work with a stock truck?
Old Jun 20, 2008 | 05:58 PM
tjbeggs's Avatar
tjbeggs
It won't be needed on a stock truck. its not needed on some modded trucks either. Some like mine need it. Some trucks its an issue some its not.
slk133
May 3, 2008 07:16 PM
rosa70
Dec 4, 2004 08:03 AM
CAT_man_963
May 3, 2004 06:33 PM
amsnss
Jan 11, 2003 02:54 PM
nmaineron
Mar 8, 2002 01:07 PM
